RC10B4.1 FT/WC
Old 01-14-2012 | 12:59 AM
  #9736
Wild Cherry's Avatar
Originally Posted by Rotax125
I cant beleave how many just copy other peoples settings because they dont know what does what to a car..Just because it works for the fast guys..I dont run Cav's set up from the worlds.. I dont run on a track like the worlds track, nor at the same time as the worlds. Hell, i dont even drive like Cav. (im still up the front tho) Knowing how to setup for YOUR driving and TRACK is what every one should be doing.. This shit about i dont have time to test..BS..Make it..
Off my soap box now..
Good set-ups take time to develop even by the Ae team , so why pass up a easy short cut towards making a faster car ?
Wild Cherry is offline
Old 01-14-2012 | 01:08 AM
  #9737
Are you running on the same track? Is the clay the same? NO.. Do you drive the same ? NO. Is your car identical? NO. DO you know how to set up?
Flame suit on..
Rotax125 is offline
Old 01-14-2012 | 01:14 AM
  #9738
Originally Posted by Kave
a great starting point on most of not all surfaces and conditions.
Not really.. Ive tried these set ups and i ALLWAYS end up some where else.. Yeah they may be close to the way some people set up, but hay, if you like to follow that s great..
Rotax125 is offline
Old 01-14-2012 | 02:16 AM
  #9739
Registered User
Originally Posted by Slashdrivr
Got my WE B4.1 on order...local classes have gone back to "stock" being 17.5/blinky.
Just grabbed a 17.5 ReVtech, and plan on using a GTB and spare Align DS620 servo I've had laying around. Picking up some gold Barcodes F/R tonight...can't wait...
I recently picked up a 17.5 Revtech and love it. This is a great motor and is just as quick as the other guys at my track running 13.5s and it runs very cool
Ryno B4.1 is offline
Old 01-14-2012 | 02:34 AM
  #9740
MOmo's Avatar
Flame suit on..
Have you seen WC's post count? have you seen his comments in this thread and others with regards to setup and handling? The man has raced quite a bit and has a great deal of knowledge of this and other cars.
Setups are designed to get the builder moving in the right direction in getting a car to handle and respond accordingly and with minimal hair loss.
Yes, not EVERY setup will apply to every possible track, but a baseline setup will be far better than grasping as straws and struggling to get the car to work right. Just about every company has a neutral starting point and you go from there. With the increased use of Lipo, weights made a huge difference and now a lighter handling car changes things thus changes are made.
I know that I might not drive like Cav or Mayfield but if i see that my track mirrors a setup that they used, I would probably start there and test it and small adjustments as needed. Its also why I like to get feedback from other drivers about how my car feels because I personally am not technically minded to understand how the changes to suspension geometry affect how my car handles, but I change my style to suit the car, NOT the other way around, which IMO is what people should be doing.
On that note:
Running an 8.5 motor, what spur are people going with? Mainly running on a tight indoor Clay, high to med traction.
Momo
MOmo is offline
Old 01-14-2012 | 02:48 AM
  #9741
Just1More's Avatar
I personally change the car to suit my driving style..if i like to power out of corners but hug the inside line, i make a change for more exit steering and watch lap times..I hear people all the time saying that their car works good enough so they don't touch it. I couldn't be happy with that state of mind but to each his own.
Just1More is offline
Old 01-14-2012 | 02:52 AM
  #9742
On that note:
Momo
I agree.. WC is a legend.. With setups, ppl should look to find what their own base line is & go from there, not just copy what "he" runs..You will be a far better driver for it..
Id run a 84T spur for a tight track, but thats me.. A tight track for me is 200 meters long.
Rotax125 is offline
Old 01-14-2012 | 05:11 AM
  #9743
tq_danpatterson's Avatar
There's nothing wrong with using pre-existing setups. Remember that when you're a rookie who's never tuned your car before, having all those adjustments suddenly becoming important can seem daunting, and even a turn-off. You can't expect newbies to just automatically be interested in understanding caster, camber, toe, roll center, shock setup, spring rates, weight ballasting, etc., when all they really want to do is hit the track and drive. That's like expecting a ten-year-old to automatically be interested in school. (Not accusing anyone of being immature, just an analogy!) Yes, some individuals, when they are first starting out, are interested in the technical side of car setup, but most are not. Everyone learns at their own pace. And that learning would be a lot more difficult if successful setups were not available.
tq_danpatterson is offline
Old 01-14-2012 | 05:45 AM
  #9744
idrummerboy13's Avatar
Flame suit on..
I use setups for a base, if i want rotation i try a stiffer spring, more steering, softer front. More side bite etc etc
Just so happens cherrys setup he posted is what I found my self using when I rebuilt the car and threw it back. That was before I saw it lol
Ik how to tune, and I am getting better at it the more I do it. Finally realized one change at a time has to happen. If it doesnt work out, take a step back.
idrummerboy13 is offline
Old 01-14-2012 | 07:19 AM
  #9745
YankeeFan123's Avatar
On that note:
Momo
84/81, how big is tight?
YankeeFan123 is offline
Old 01-14-2012 | 07:21 AM
  #9746
B.A. Racer's Avatar
i run 81 spur with 21-23 pinion wherever i go
B.A. Racer is offline
Old 01-14-2012 | 07:54 AM
  #9747
rosko's Avatar
I thought 90% of set up was tires. 95% of your set up u call your own is probably about 5% different than cav or mayfield, so y knock the person wanting to try cav or may. Set up when your really doing the samething
rosko is offline
Old 01-14-2012 | 09:18 AM
  #9748
Default Help needed
Hi....new to the forum. I've been out of racing for years, but recently decided to get back in. I bought a RTR B4.1 and the X-6^2 kit (along with some new electronics) to make some performance improvements. I'm almost nearly complete with the mod and seem to be having an issue with the RTR rear axle/dogbone set-up. It appears that the X-6^2 manual shows the CVA/CVD style axle set up. Does anyone know if I need to convert from the Team Associated Dogbone and Hub set-up to the CVA or CVD and Hub set up that would have come with the B4 kit? Is there are longer dogbone that I can switch to....maybe some other manufacturer??? Your help is appreciated.
jmhill13 is offline
Old 01-14-2012 | 09:40 AM
  #9749
DaveW's Avatar
You guys have gotta realize... not everyone races RC and truly guns to be the fastest. Some actually get into it for the FUN. Some would rather drive more than tweak all day. Me, im a tweaker. But i respect the desire for those who wish to have more fun than work at the track...
DaveW is offline
Old 01-14-2012 | 10:16 AM
  #9750
bds81175's Avatar
Moderator
jmhill13, I PMed you.
bds81175 is offline
