RC10B4.1 FT/WC
#9677
so for me id take a slightly slower servo with 40oz more torque vs a faster servo with less...
i also think the largest upgrade you can do is to a digital servo, they seem to center alot better, and have stronger holding power...
i really love the ace/xp digital servos the 1313 is a really nice servo with ~180ozin torque and .13s speed for $75 brand new -- can be found on the forsale section for 35-40 normally
#9678
in genral ur like said ur shock say 30wt with 2 hole will never be like my 3owt 2 hole shock.. 1 just bye how you build them, like how much bind or rub in your piston and shock body, or how much blow bye there is,or if u did have a tight piston and u fitted it are the edges round or square, is your piston shimmed so theres no wobble, how worn are ur shockshafts, ect, ect, ect... In any setup or question it just goes bye genral theroy really... youknow what i mean...
shoot i wouldlove to have the same feel as cav,tebo,or mayfeild in my shocks but who know reallylike was said dont know what u may stumble on if u dont try...
But in my eyes.. wouldnt you want the smoothes, free flowing, no bind but not too much play shock? kinda like a arm u def want it to be free..the whole point in the sus system is for it too take the impact of the bumps an surface not have a factor beside the wt oil or size hole..? right?
I undersstand the theory behind this but I don't know if I agree with it. You are completely changing the characteristics of your shock setup, which will make it impossible for everyone to help when you need it. I mean your shock with 30 wt and 2 hole won't feel like my shock with 30 wt and 2 hole.
#9679
after using .07s servos and .11s servos, i cant feel very much difference in the speed - the accompanying torque that comes with the slightly slower servo i can feel on high bite tracks....
#9680
Has anyone ever used rudebits or any other wieghts that compensate for the lack of weight with the lipo batteries in the b4.1? I currently use the rear ballast and some lead weights in the front. Just wanted to get some insight in how the car handles and such.
#9682
Here's a quick setup guide i found on Petit RC, enjoy!
http://www.petitrc.com/reglages/BuggySetupGuide.pdf
is it the distance between the inside of the tires?
what is ackerman and how do you adjust it?
thx!
#9684
#9685
Since the RTR (here we go again) receiver is on the slow side, would replacing it be recommended for an amateur? Seems like a "fast-twitch" servo might cause more problems than it solves... not much point in buying a great servo if you wind up having to trim it down because you can't control it.
Or, is it really worth the extra dough, and something you'll get used to quickly?
Front
SC10RS steering blocks #9880
B4 hex axles #7496
HEX adapters #3973 ( only fit the front) You can also use 9497 which is AE's front/rear hex package
Ball stud locking nuts for the blocks. #4449. SC10RS and SC10 ones are different
Rear
Hex-JConcepts Rear Hex Adaptor 12mm B4.1/B44.1 Blue #2091
I know I can feel a difference coming from a faster Servo to a slower servo.
#9686
Has anyone tried Schmacher BB springs on their B4/4.1 ? Do they fit Associated shock bodies ?
Just out of interest, with the Worlds kit coming out soon, how many people would like to see the kit come with a "spec" and "mod" sized spur gear ? With blinky 17.5 class becoming the norm (and 540 "silver can" class down here), people have to attack their motor plates with a dremel to make the big pinion/small spur combos fit.
It would be nice to see an option for a different sized spur gear in the kit (they're cheap), instead of having to purchase it separately (or perhaps a motor plate with bigger mounting holes).
#9687
#9690
on some of the setup sheets, the racers have 2mm spacer listed on bump steer.
is this bump-steer location the place where the turnbuckle connects that control toe-in? or?
