RC10B4.1 FT/WC
Old 01-26-2012 | 01:26 PM
  #10426
indy34096's Avatar
Maybe a bit off topic right now, but does anyone have a good way of getting the receiver wire up the antenna tube on the chassis? The only holes to get up the tube are from the bottom of the chassis or from the side inside the chassis, where you have to get the wire to go in and up to have the tube right.
I wish it was like most other 10th scale chassis, with a slot in the side of the antenna tube holder so the wire has a place to stick out.
Ideas?
indy34096 is offline
Old 01-26-2012 | 01:27 PM
  #10427
if everyone knew the amount of stuff that BWald is responsible for coming to life in the production world, the earth would implode.
I mean think about it.... every major company has a version of his tire
He's a legend and I hope he gets the win this weekend!
Bob Barry is offline
Old 01-26-2012 | 01:37 PM
  #10428
nismomike's Avatar
I dont see a spring cup on the shock either. To me it looks like a BB sleeve that threads over the AE threads and allows you to use a certain spring retainer. Although that does not explain the missing spring cup. Might just be a picture showing off the sleeve and the springs/cups were removed to make it more visable.
nismomike is offline
Old 01-26-2012 | 01:42 PM
  #10429
nismomike's Avatar
Anyone know how to mount their wing like that, with the cone washers and tapered head screws?
Old 01-26-2012 | 01:45 PM
  #10430
Good eye. I wouldn't mind doing that myself. Curious as to what mounts he uses
Old 01-26-2012 | 01:46 PM
  #10431
Asharus's Avatar
i believe someone on the thread did this a little while ago. from what i can recall, they just dremeled the post flat, drilled a hole and used a cone washer/screw to secure the wing to the posts.
Asharus is offline
Old 01-26-2012 | 01:53 PM
  #10432
nismomike's Avatar
Very easy, I'm gonna do it tonight. I hate a loose wing!
Old 01-26-2012 | 02:00 PM
  #10433
andrew-01's Avatar
Been running mine this way for the past year or so.
Just shaved the top nubs flat, drilled and tapped two holes. It seems to help with keeping the wing more secure/straight than with the body clips etc.
andrew-01 is offline
Old 01-26-2012 | 02:01 PM
  #10434
Matt Trimmings's Avatar
The shock is a standard v2 shock. He just used a lathe to take the hex off the body. Dont read too much into this, he obviously isn't running the car...he probably built his shocks and didn't put the springs on yet.
Matt Trimmings is offline
  #10435
20 SMOKE's Avatar
20 SMOKE is offline
Old 01-26-2012 | 02:04 PM
  #10436
Originally Posted by 20 SMOKE
if you look at the bottom of the shock there is a hex,looks like BK is using is own style shock
The bottom looks just like every other v2 shock out there.
Old 01-26-2012 | 02:07 PM
  #10437
20 SMOKE's Avatar
yeah after looking at it i see it,hara is running bb springs looks to be a little different collar,pics are on FB
20 SMOKE is offline
Old 01-26-2012 | 02:08 PM
  #10438
jf+'s Avatar
jf+
Originally Posted by MikeInCtown
Since I didn't see an "Official RC10B4.1RTR thread" I figured this one covers the 4.1 everything?
Anyway, i was thinking about getting either a couple used 4.1s for my kids and picking up some radios.. OR picking up the 4.1 RTR brushless kits they sell now for $250.
Does anyone have any experience with the RTR kits? I'm looking for something they can have fun with, yet something that isn't going to break if they stare at it too long and also something that I can go grab parts for easily. (are team parts interchangeable? -now world I guess) Had thought of the Losi kits but they are like $150 more and I'm not sure they are worth the extra $300 for the pair I'd need to get.
Thanks Guys
I bought the same kit for $225 and I really like it.. The motor is plenty strong, it's reasonably easy to drive, has plenty of pep, and if you don't mess with it too much it should be a lot of fun. Despite what others have said here and elsewhere, I don't see the problem with bashing this car. Maybe if you're ridiculously careless or mean, you might have an issue, but mine has been tough as nails even through some unintentionally stupid moves. You can pick up a $25 Turnigy 2s 20-30c 5000mAh lipo from HobbyKing.com that will provide ample power and at least 30-40 minutes of solid run time. As for a charger, Amazon's got a Tenergy charger+power supply combo for less than $50 that will work great for charging/balancing your batteries. So to actually get running, you're looking at $300.
I think it's an easy car to work on, even for a complete noob like me, and it will provide hours of tinkering fun.. As for those who suggest you should get the world kit or whatever, yeah, you could, wouldn't be dumb by any means. The kit is $250 or so, but you have to paint the body, buy a servo, buy a motor, buy an ESC, buy a controller and a transmitter, buy a battery and buy a charger. If you're anything like me, you're not going to buy crap, so by the time you're done, you're looking at $550-650 easy (unless you scour used parts online for weeks to piece it all together).
I'm sure there are folks that can put it together for less, but if you're starting from scratch, the RTR is just much easier and you can be on the road (with a paint job!) much sooner. Many of the FT parts are just pretty things that won't necessarily enhance your enjoyment of the car or it's driveability. Then again, they certainly don't detract from it. Now, the V2 shocks are definitely a worthwhile upgrade, but if you've read more than 3 posts here, you know that lots of folks aren't using those anymore either (going with Kyosho shocks, Losi springs, etc. etc. ad nauseam.)
Bottom line is, I've been really happy with mine, and I'm glad I went the RTR route. Much easier pathway to the hobby than piecing it all together. In the end, you may well spend more turning your RTR into a World's Car, but it's more likely (in my opinion) that you'd never do all those upgrades to the roller anyway. You'll probably be more like me and blow most of your cash on tires.
jf+ is offline
Old 01-26-2012 | 02:09 PM
  #10439
lip
Default Wrap for jconcepts finnisher +8mm B4.1?
Does anyone make one yet? I've asked a couple and most will be coming out...nothing out yet...
lip is offline
Old 01-26-2012 | 02:51 PM
  #10440
Jmuck69's Avatar
I think he uses the buttons from the Durango 410.
Jmuck69 is offline
