Like Tree5Likes
SC10 4x4 Thread
Old 01-06-2012 | 04:55 AM
  #14191
SCTDan's Avatar
Originally Posted by AzFittin
I really do like the changes it makes. Granted I do not have much test time but really can see a difference. The only issue I have noticed, and this is very minor, is that I cannot tighten the nut enough to fully lock the ball diff. Some habits are hard to break so my initial setup included the old toss the truck away from you and floor it back towards you test. This is good for slipper setups but also will tell you if there are other issues. With my truck (on carpet) I can hear the tell-tale grinding noise of the ball diff slipping between the plates on initial take off. Not sure if you have ever had an old MIP tranny, especially the replacement ones for the AE kits, but if you have you know the sound I am talking about. Just to be clear, this is only happening on the carpet where there is more traction than probably anywhere else you will encounter and I am not at all worried about it as this tiny amount of slip will not create enough heat to cause any issues.
Did you flip the washer between the spring and the lock nut? This allows you to fully compress the spring.
SCTDan is offline
Old 01-06-2012 | 05:04 AM
  #14192
SCTDan's Avatar
Originally Posted by Mizchief
Isn't that a good thing? It's better to slip a bit than to strip out a gear or wheelie out of control right?
You can't really wheelie with the ball dif. When the front wheels start to lift they lose some traction and power is diverted to them and taken from the rear. You don't want to slip a ball diff. It will groove and pit the rings requiring replacement or resurfacing.
SCTDan is offline
Old 01-06-2012 | 06:20 AM
  #14193
MantisWorx's Avatar
AZ that is a bit strange but if you are on carpet it is possible. your not going to have that much traction on any track! interesting though that during testing i left mine loose for an entire race and couldnt hear anything, it just slipped with no sound?? and i am still running the same plates and balls. one thing you can do is install the V2 HD spring and it will put more pressure on the plates.
actualy i just re-read your post, your actually pushing the truck away from you and flooring it?? Lets not do that anymore!! not good for a heavy 4wd truck compared to a lightwieght 2wd buggy!
MantisWorx is offline
Old 01-06-2012 | 06:33 AM
  #14194
symmetricon's Avatar
Originally Posted by CoyoteSlash
Exotek Chassis
Mantis Center Diff
Mantis Dual Stage
B44. Saddle pack mod
ThunderPower 1S 65S 5400 x2
~on order
I hate you guys... so much.
Welcome to the darkside muhahahaha!
symmetricon is offline
Old 01-06-2012 | 06:46 AM
  #14195
You also want to make sure that you do not have it set to tight. Also make sure the ball diff assembly is well lubed.
Old 01-06-2012 | 08:06 AM
  #14196
CoyoteSlash's Avatar
I instinctively hate Balldiffs. (I dunno. They just bug me.) But this one is so easy to get to, so that'll keep me happy. =)
Plans within the month:
Test Exotek over my CoyoteTek Chassis with Reflex Racing Top-plate.
Swap my 1415 for my 1410 to run the Center diff with that cursed 62t spur
Test Saddles over my Stickpacks. (I already know the outcome)
Begin Bash testing the New CoyoteTek FT Chassis Brace: I will get pictures up as soon as "I've" seen the thing. And I'll open orders once again. (you guys waiting are first most obviously.)
Inbetween that I have work, and classes.
CoyoteSlash is offline
Old 01-06-2012 | 08:11 AM
  #14197
vito's Avatar
Originally Posted by BlueGlowBoy
Don't ask us why your truck takes so long to steer and gets really uncontrollable through the rough sections of the track....
i know it slow as but it all i had at the time.
vito is offline
Old 01-06-2012 | 08:39 AM
  #14198
vito's Avatar
my weekend is to get my truck done and set up later
vito is offline
Old 01-06-2012 | 09:09 AM
  #14199
johnbugman's Avatar
Originally Posted by thebizz
I was able to battle with those losi beasts!
nice paint scheme. like it
johnbugman is offline
Old 01-06-2012 | 09:12 AM
  #14200
johnbugman's Avatar
guys just check out johnbugman on youtube youll see some nice sc104x4 action there.... carpet and orange clay.
Old 01-06-2012 | 09:38 AM
  #14201
Steve737's Avatar
If you are planning on eventually getting a new servo, don't assemble the front end yet. There is a lot of disassembly to get to the servo. Trust me.
Steve737 is offline
Old 01-06-2012 | 09:45 AM
  #14202
vito's Avatar
i have a air metal case srevo in a gt 2 its a high speed one will it work i dont know the specs . do i pull it and swap them over?if i pull it and post a pic some knows if it is a good one ?
vito is offline
Old 01-06-2012 | 10:03 AM
  #14203
vito's Avatar
Default servo
help is this a better one to use its a airtronics 94360? thank you
vito is offline
Old 01-06-2012 | 10:24 AM
  #14204
Chad Smith's Avatar
Yes the speed is .07 @ 6v and the tourqe is low at only 125oz @ 6v but will work.
Chad Smith is offline
Old 01-06-2012 | 10:31 AM
  #14205
Nyk
Not a 100% but I think with airtronics servos you will need an extension wire...
Nyk is offline
