Team Associated RC8Be Thread >
Old 01-01-2012 | 02:29 PM
  #7291
Lynxette's Avatar
Originally Posted by derekbsmith
What are a few of the best after market carbon chassis for the rc8be?
snrgraphite.com
bcespeed.com
thx!
As far as i know snrgraphite is the only carbon fibre chassis available
Lynxette is offline
Old 01-01-2012 | 02:30 PM
  #7292
jmackani's Avatar
Originally Posted by slashracer111
This buggy is still super fast, and still winning against the 8.2s.
I do have one issue though. I broke my rear chassis brace at the track the other day. I'm debating if I should go with a pivot ball style brace, or a plastic stock brace. I run on rutted out 1/8 scale tracks, so by getting the solid FT brace, I will sacrifice traction and chassis flex too much.
We went to the solid aluminum and it really did not change the flex as bad as you would think. In addition, last week my son which has both the 8be and 8.2, though the 8.2 is not built for him yet, set his 8be on the TQ spot against other 8.2 vehicles. I have two sons and the other one did have 8.2 on the track and finished 4th. The oldest one did drive the 8.2 and he does think he will be better with it.
jmackani is offline
Old 01-01-2012 | 02:34 PM
  #7293
slashracer111's Avatar
I'll defiantly be getting the RC8.2 whenever funds allow, no doubt. I'm trying to sell some things off to buy a new one.
Is your son running the Aluminum front brace too? I may go ahead and pick one up while I'm at it.
Sigh. Racing three classes every other weekend isn't very cost effective.
slashracer111 is offline
Old 01-01-2012 | 03:39 PM
  #7294
jmackani's Avatar
We are still running the stock brace on the front. We have only seen the rear braces having breakage problems. Kind of funny both of ours broke on the same track on the same day. It was a rough track and I honestly think it may flex too much on the rough tracks with the stock brace. If that was not the case, then I can't explain both vehicles breaking on the same day at the same track.
jmackani is offline
Old 01-01-2012 | 05:12 PM
  #7295
sc10rr's Avatar
any advantage too running a carbon fiber chassis? they do look good
sc10rr is offline
Old 01-01-2012 | 05:32 PM
  #7296
jmackani's Avatar
They are a lighter and probably flex differently. To be honest, most of these electric cars need the extra weight to put down the amount of power the motors are capable of. I am a firm believer in this class, lighter does not help the vehicle at all. In addition, for the expense of the chassis, I think I would cry seeing a scratch put into it. It's not like we are running these like a touring car on clean tracks and no jumps.
jmackani is offline
Old 01-01-2012 | 06:46 PM
  #7297
dirtman71's Avatar
So since I have an RC8b nitro I converted to electric, do you know what the chasis differences are between the rc8be?
dirtman71 is offline
Old 01-01-2012 | 06:47 PM
  #7298
Mxer59's Avatar
Just installed my mud guards on my rc8be from de. Wanting to adjust shocks what oils should I run in front and back
Mxer59 is offline
Old 01-01-2012 | 08:29 PM
  #7299
beidle99's Avatar
Whats the biggest diameter motor that can be installed with the stock motor mount? I currently have a 36mm and can see where the chassis flexed and the motor hit the foam pad. something to worry about?
beidle99 is offline
Old 01-01-2012 | 10:56 PM
  #7300
Vp special k's Avatar
whats up everybody, new to the forum but not to the hobby. I recently just finished building my rc8be FT kit. Its finally up and running with the Xerun 150a esc and turnigy trackstar motor. I have it on 2x2s gen ace packs and I;m loving every minute! I have a savox 1258tg steering servo which I am extremely happy with.
what pinion gear is everyone running with a motor that is 2560kv? I'm using the stock gears seems to run fine and everything stays cool, I'm thinking maybe I can go up a couple teeths.
Vp special k is offline
Old 01-02-2012 | 10:43 AM
  #7301
Depends on how small/large/technical your track is. Most people have 14-16t pinions on standby. However I have seen speed demons fit a 20t pinion on for street running. So just gear accordingly and watch your temps.
alexchen86 is offline
Old 01-02-2012 | 12:08 PM
  #7302
Which mudguards? I have an RC8 FT that I turned into an RC8Be, but I have no mudguards on the rear arms. Which arms have the holes in them for the mudguards?
Also, do the 8.2 rear arms fit right on?
ChrisH02 is offline
Old 01-02-2012 | 12:17 PM
  #7303
Mxer59's Avatar
I do not no about the 8.2 as I believe they have holes in the arm for them. As for mine I got them off of amainhobbies they are a clap style around rear arms then screw together to lock them on. They are made by DE and are pretty easy to put on after I get car back together I will post a pic to show them
Mxer59 is offline
Old 01-02-2012 | 03:20 PM
  #7304
I just ordered up DE mud guards last night as well for my RC8Be I just put together. Got a TBR pro nylon front skid bumper coming as well.
Also my steel 46t spur gear arrived. I'll be replacing the plastic one once it wears out.
Currently running 5k diff oil on all 3. The track I'll be practicing on most of the time is pretty technical as it was designed for SCT's.
Should I run something like 3k 5k 7k?
Also I'm using a Futaba 4PL with the included SFHSS RXwith a digital Hitec 7955TG servo...can I run high response time off the TX or stick with normal response? Is there that much of a difference?
Old 01-02-2012 | 04:27 PM
  #7305
are there any mods that need to be done to run the DE mud guards?
