SC10 4x4 Thread
...There are about 5 sc10 4wds, and all run great with stock gear using many diff setups/motors...Mine included..I run mostly on on a big 8th scale wide open dry/dusty and loose, dirt roosting track, and sometimes also in a high grip indoor track...No one has truly needed these hop-ups....
Certainly you are entitled to your opinion.
I wish it was a build problem. If you follow the instructions, there is only one way to build the slipper. It's not that complicated. Then AE started using the clutch basket on the team trucks, the same weekend they started running 550 motors. And winning big races.
Which four pole are you running?
That honestly can't even be an opinion at this point.
I'll gladly be the first one to tell someone when I don't think an upgrade is necessary. (Example: My ugly lead weight shoved in areas of my truck and a Chassis brace over the Exotek chassis.)
Started mine last night and got it finished today. So far I love the truck and cant believe how easily went together. I even got the body painted today. Hitting the track tomorrow for testing and fine tuning.
thanks,it was easy to do as long as you have a drill and dremel handy, you'll need the dremel to sunken the hole underneath for the screws. I ordered it about a week go. it really is high grade quality and the fit and finish is perfect!
5Likes
