Like Tree5Likes
SC10 4x4 Thread
Old 12-27-2011 | 09:38 PM
  #13231
nmdesertracer's Avatar
The truck should have came with swaybars!
nmdesertracer is offline
Old 12-27-2011 | 09:43 PM
  #13232
rsd kit came in and installed! thanks Christian!!
derbrylac is offline
Old 12-27-2011 | 09:52 PM
  #13233
CraigMBA's Avatar
Originally Posted by MarqueeRc
...There are about 5 sc10 4wds, and all run great with stock gear using many diff setups/motors...Mine included..I run mostly on on a big 8th scale wide open dry/dusty and loose, dirt roosting track, and sometimes also in a high grip indoor track...No one has truly needed these hop-ups....
I respectfully disagree. If you guys are having fun at your track, game on and don't let me stop you, but a $50 for a slipper basket and a chassis brace will pay for itself a couple of times over in belts and melted spurs.
Certainly you are entitled to your opinion.
CraigMBA is offline
Old 12-27-2011 | 10:05 PM
  #13234
MarqueeRc's Avatar
As are you, but again I have seen none of this happen to many properly built sc10 4wd's..Im running a four pole motor and simply have not encountered these horror stories..To you and your brosef slasher, lets just agree to disagree!
MarqueeRc is offline
Old 12-27-2011 | 10:09 PM
  #13235
CraigMBA's Avatar
It's not an assembly problem. I think it's a torque problem. The users who ran 540 motors didn't have any slipper issues (but did have heat issues), users tuning 6.5 550 motors seemed okay. Once you got to a 5.5 550 or more just about everyone had issues. I'll do a search and document it for you if you want.
I wish it was a build problem. If you follow the instructions, there is only one way to build the slipper. It's not that complicated. Then AE started using the clutch basket on the team trucks, the same weekend they started running 550 motors. And winning big races.
Which four pole are you running?
CraigMBA is offline
Old 12-27-2011 | 10:10 PM
  #13236
CoyoteSlash's Avatar
But that implies that thousands of people did not properly build their Sc10 4x4's man. It's just flat. out. Wrong.
That honestly can't even be an opinion at this point.
I'll gladly be the first one to tell someone when I don't think an upgrade is necessary. (Example: My ugly lead weight shoved in areas of my truck and a Chassis brace over the Exotek chassis.)
CoyoteSlash is offline
Old 12-27-2011 | 10:32 PM
  #13237
Started mine last night and got it finished today. So far I love the truck and cant believe how easily went together. I even got the body painted today. Hitting the track tomorrow for testing and fine tuning.
losifiend is offline
Old 12-27-2011 | 10:33 PM
  #13238
Steve737's Avatar
I like the mature back and forth, it's a great way to learn. Please continue.
Steve737 is offline
  #13239
Looks good. Now if only we can change that teeeeeeeeeerrible screen-name.
Old 12-27-2011 | 10:35 PM
  #13240
Chad Smith's Avatar
Looks very nice
I plan on buying this conversion kit was it easy to install? And when did you order it that you received it already?
Chad Smith is offline
Old 12-27-2011 | 10:38 PM
  #13241
now grab that clutch basket and let err rip!!!
Old 12-27-2011 | 10:41 PM
  #13242
Originally Posted by Chad Smith
Looks very nice
thanks,it was easy to do as long as you have a drill and dremel handy, you'll need the dremel to sunken the hole underneath for the screws. I ordered it about a week go. it really is high grade quality and the fit and finish is perfect!
  #13243
Haha, nope! This is my first AE RC. 95% of all my land RC's I have owned have been Losi's.
But you can call me Rafael if it makes you feel more comfortable.
Old 12-27-2011 | 10:44 PM
  #13244
lodhammerdin's Avatar
Tell Lod and only Lod that.
Sure tell me and only me. Im the only person who ever does anything wrong, o and cherry apparently. Gotcha.
lodhammerdin is offline
Old 12-27-2011 | 11:06 PM
  #13245
Raffy it is!
