RC10B4.1 FT/WC
Old 12-26-2011 | 11:33 AM
  #8881
Originally Posted by Jerz616
Well you are running a 13.5 with boost. I am running a 17.5 no boost. So I need that extra top end. When I run my 13.5 D3 I gear it at about 78/25 or 27, and it has everything i need.
Top end is the last thing I need. I need that low end snap. It's funny, I just pulled my gearing from the AE Manual to start with but I think I was looking at the wrong turn motor on the chart. It suggests 28/75 for 13.5 and 25/81 for 10.5. I must have looked at it too quickly.
your 13.5 gearing ranges from 8.112 (25 tooth) to 7.511 (27 tooth) with the new motor.
Mine is 9.156 (23/81). I guess I'm just way out of the power band......guess I need to change it up.
Bob Barry is offline
Old 12-26-2011 | 11:36 AM
  #8882
OHHHH wait I see exactly what I did. Since I had just come back to racing, I never ran brushless before and I remember asking what the brushed equiv of a 13.5T was so I could guage it... I was told a beefed up 19T. I just looked and the suggested gearing in the manual for "19T Super Stock Motor" is 22/81 (where I was starting).... Didn't click that was 19T brushless and completely the wrong gearing LOL.
Old 12-26-2011 | 11:41 AM
  #8883
skengines's Avatar
Originally Posted by jmoneym
Anybody have both the B4.1 +8 and regular Proline Bulldog body . Are the dimension pretty much the same? Looking to order a Upgrade wrap for the +8 body.
I have both and they fit fine for me. I heard the regular AE b4.1 body will not fit on the +8 chassis though.
skengines is offline
  #8884
T-BirdJunkie's Avatar
No, that 19t refers to brushed, but you gear a brushless motor way taller than you gear an equivalent brushed motor (IE 27t you'd never run a 33t pinion).
BTW those FTW bodies are butt-arse ugly. Blech.
T-BirdJunkie is offline
Old 12-26-2011 | 11:44 AM
  #8885
ya I'm straight now........ I see the mistake. Chalk it up to noobnes and a 6 year layoff
Old 12-26-2011 | 11:48 AM
  #8886
Don't worry, this time two years ago ThunderbirdJunkie was there
Old 12-26-2011 | 11:54 AM
  #8887
wow, I knew I wasn't going crazy.
http://www.teamassociated.com/pdf/ca...-preflight.pdf
Scroll down to page 34. Shows the gear chart. It has the WRONG info in it for 13.5 for sure.
says to run 20/81 to get a 6.96 FDR. 20/81 actually gives you a 10.53 THAT is why I was so jacked up.
if you look at the online manual for the non factory team car, it shows the correct 28/75 ratio 6.964 FDR.
I feel like Sherlock Holmes trying to piece this stuff together hahaha
Old 12-26-2011 | 12:11 PM
  #8888
ses601's Avatar
my stocker fit just fine with the +8
im runnin 23/81 on an ollllllld lrp 8.5.......bob i think we are both running the same track (ecrcr) right?
ses601 is offline
Old 12-26-2011 | 12:30 PM
  #8889
I'm planning on a LRP 9.5 at that track. My B4.1 should be here this week.
Guess a 23/81 should be fine?
jmoneym is offline
Old 12-26-2011 | 12:43 PM
  #8890
racer1812's Avatar
Super Moderator
Originally Posted by D-Rek07
What pinion gear should I use on a b4.1 on an indoor clay track with an 81 tooth spur gear to run in the 17.5 non timing class?
Originally Posted by JFuel11
You can use the 81 but I would drop to the 78 or 75 if you can. I would start with a 27 or 28 and work your way up from there but most likely you will end up around 78/31 with a non-timing setup. Always keep tabs on your motor temp.
You may run out of space with the 81 in order to get a large enough pinion on for 17.5 non-boosted.
I run a 17.5 non-boosted and I am geared at 72/35 for a FDR of 5.2. I use a Fantom Apex with the motor timing about 2.5 clicks past middle. I have also ran 75/33 and was pretty fast also. With the 17.5 blinky class we need as much top end as we can get, and the 72/35 works really well. If you get to much heat you can run the 75/33 and still be pretty fast.
mine ran cool geared at this. FYI 35 is the biggest I could fit, a 36 would hit the heads of the motor screws.
racer1812 is offline
Old 12-26-2011 | 12:55 PM
  #8891
ses601's Avatar
i would think its in the ballpark. of course tires, motor, esc, boost, etc. can all have a bit of an impact. my gearing is with holeshots and an old gtb speedo, and a preference for putting power down smoothly
ses601 is offline
Old 12-26-2011 | 12:59 PM
  #8892
racer1812's Avatar
Super Moderator
I wouldn't be surprised to see 24/81 work fine as well. LRP's are good with a little more heat (180 ish). Many guys are running 23/81 on an 8.5 with no issues.
suggestions are always fine but nothing beats a temp gun..
Old 12-26-2011 | 01:30 PM
  #8893
Yessir.
I will be up to speed next time out
Old 12-26-2011 | 05:38 PM
  #8894
My gearing on 8.5 is 23/75
I just cant get the buggy to pitch in the air!
I hit the brakes and the nose wont drop!
Fred Perkins is offline
Old 12-26-2011 | 05:59 PM
  #8895
bigs's Avatar
Originally Posted by bds81175
Folks take the pad that the ball studs thread into down flush with the rest of the U brace.
Are they moving the outer ball stud down too ?
bigs is offline
