Like Tree1Likes
B44.1 Thread
Old 12-18-2011 | 05:58 AM
  #961
Originally Posted by UN4RACING
I like them. But I just want to be able to say i have big ones to.... tee hee.
Are you sure your building them correctly? Which set are we talking about?
Built them according to the manual and a couple other ways. They are ok for about 1 run after a build and then they go to crap again.
jsmax is offline
Old 12-18-2011 | 06:14 AM
  #962
UN4RACING's Avatar
You could try losi oil? Or thicker oil? I get a couple of weeks then top them off and bleed them again. I run stock set up 30/35 #1&2 pistons. Let there be big bores.
UN4RACING is offline
Old 12-18-2011 | 06:20 AM
  #963
idrummerboy13's Avatar
are there any tips or upgrades for this? Ik rear swaybar. Been racing my b4.1 for a year and got the hang of it pretty well so I would like to get a b44.1 for christmas. Hows the savox 1257tg? (forr this car)
idrummerboy13 is offline
Old 12-18-2011 | 06:34 AM
  #964
UN4RACING's Avatar
I do have some tips on shocks. 1st build you lose oil to the O-ring resivoir as the rings will swell and oil fills the area around the spacer between them. I like to soak my rings a day ahead, the factory drivers at our track use the old white spacer claiming smoother better plush feel and seal. Prime the O-ring area with oil real well to. Slime is fine but I prefer using the oil of choice. Presoaking the ring gets you a more broke in feel asap. Hope this helps. I'm running the V-2 shocks and this method works well on the old ones as well but you have to have the bleeder caps to fully benifit a good shock performance.
Old 12-18-2011 | 06:38 AM
  #965
rcJRfromOK's Avatar
Just acquired a b44.1 and am needing electronics. I'm getting a Novak GTB and 8.5 motor. How well with this combo work in this buggy? Also looking at the 6000mah GensAce saddles, but at a 25c will they perform well in this buggy? Thanks in advance.
rcJRfromOK is offline
Old 12-18-2011 | 06:41 AM
  #966
UN4RACING's Avatar
The B44.1. Is dialed right out of the box. I kid you not! Nothing is required, build it box stock and race. Sway bars battery carbon hold down its in the kit. I have done nothing to mine. I run the LRP 1015 servo. Cant help you on the quality of the savox. I do see a lot of them though. Must be priced right or good..?
Old 12-18-2011 | 06:49 AM
  #967
UN4RACING's Avatar
That set up will work. Those Gen Ace are a popular breed but I urge the the Reedy 5200. Nice snug fit. I personally wouldn't spare cost on batteries. Thats the heart of your whole system.
Old 12-18-2011 | 10:10 AM
  #968
UN4RACING's Avatar
When you get ready to build post up. There is a diff trick that will help now that I have had some coffee. Bzzzzzzz.
Old 12-18-2011 | 05:59 PM
  #969
-WHEELMAN-'s Avatar
Alright, I really like my B44.1, but the shocks are driving me nuts....They just feel like crap compared to all the other cars i have owned/driven. What are the alternatives for other shocks that fit and work well?
I am running Kyosho clear x-ring orings that create less drag. You need to trim the black spacer between the orings .5mm. I am also running TLR big bore springs yellow front white rear.
UPDATE: Punisher lid, cut out the four front vent options and trimmed the back out but left some for strength. 20 degree drop in temp. Gotta love it. Geared up a tooth as well.
You should try not to cut the body vents out. It looses downforce with the more vents you put. Try a fan next time.
Originally Posted by hlpressley
Are there any options available for this platform to reduce the weight at all? I am using a B44 platform in a dirt oval application and would really like to reduce the overall weight if possible. Thanks in advance..
Great car by the way
Lunsford has lots of Titanium options. At a high cost per oz.
-WHEELMAN- is offline
Old 12-18-2011 | 06:08 PM
  #970
UN4RACING's Avatar
I didn't detect any ill effect in any performance. As far as down force. I did get 20+ degree heat decrease and didn't spend a dime. I don't think the performance was decreased at all. I run a 10.5 and didn't need to cool it. Tried it mainly just to see if it helped any and it did big time. Both motor temp and ESC temp. 6.5 I think a fan would be a good idea but I would add in the vent cuts just to help. It worked and helped a lot.
Old 12-18-2011 | 06:48 PM
  #971
-WHEELMAN-'s Avatar
I ran a 5.5 on RS Pro and had to use an ESC fan and remove the front hole in the body on the ESC side. I saw very litttle temp change until I remoed a section in the rear vertical portion of the body. Air needed to get in and out! Now I run the Orion R10 ESC and a Orion Vortex 7.5 and it needs neither a fan or vents in the body.
Old 12-18-2011 | 07:59 PM
  #972
UN4RACING's Avatar
I removed both sides of the rear. The air flow has to go over the battery but it gets some good airflow. I don't think it would be a good idea on a dusty or out door track? I will get some pics up tomorrow. I left some of the lip on the rear to give it some strength.
Old 12-18-2011 | 08:59 PM
  #973
Yeah everyone was right the buggy is amazing out of the box. I switched to kyosho bigs and loved it. No more slap on huge jumps, but handling was the same other than no more bottoming out. Ae shocks are good with the old internals. I preferred the old ae shocks over the v2 though.
Will get pictures of the new paint up by tomorrow.
Ostach24 is offline
Old 12-19-2011 | 12:47 AM
  #974
Rampokker's Avatar
Originally Posted by Ostach24
Yeah everyone was right the buggy is amazing out of the box. I switched to kkyosho bigs and loved oit. No more slap on huge jumps, but handling was the same other than no more bottoming out. Ae shocks are good with the old internals. I preferred the old ae shocks over the v2 though.
Which kyosho shocks did you get? Could you give me a link to the ones you used please?
Rampokker is offline
Old 12-19-2011 | 01:16 AM
  #975
Kyosho bigs... I was talking about the big bore shocks all the kyo guys have been going nuts over. I got them for my rbi and tried them on my 44.1 and hated it with the recommended springs for the rb5 (pink front red rear) got a set for them with either yellow or gold all the way around and they are great just as good as the ae ones in handling but no slap now.
http://www.amainhobbies.com/advanced...g+bore&x=0&y=0
Hey are med and front for buggy
Ostach24 is offline
