Xray T3 2011
#3826
I race on both low grip and high grip tracks. Most are around med grip.
#3827
I'm just using a regular screw with the pivot ball joint. If I had a long ball stud I'd use it with the ball joint end. The ball stud with ball joint end have less play than the pivot ball style (less parts). However, IMO the xray turnbuckle ends are sloppy regardless of the style compared to other brands.
#3828
Well, I followed Xpress' advice n the steering and it worked wonderfully. I now have even steering both ways and the car is some much more predictable. I will follow these steps in every car I have from now on. In fact, I have a recoil pro that I thought was pointless, the car had a pretty uneven throw and I had just chaulked it up to the design. Well, I followed the details outlined by Xpress and the car drives SOOO much better. If your car doesn't have EPA's close to each other, follow this advice, it is spot on!
100 Karma Points to you!
Now, back to the "Help Mera'din set up his car" thread. I have my T3'11 dialed thanks to you guys! In fact, I finish in 1st place this last Friday. Couldn't have done it without your help. In fact, I think I may now have too much traction and I get some traction roll if i overdrive into the corners.
What is a good way to combat that without too much compromise. I toyed with the idea of only applying traction compound to the inner half of the tire. Is there something else I might give a try. Car is 1000 times better but I can't stop thinking it could be a little better/easier to drive. Here is the vid, I qualified 2nd...Any driving advice would be appreciated as well!
Now...I am not too concerned with the sedan as a few small tweaks and I am set. My VTA setup however could use some TLC. I can't seem to apply the same rules to this car as the sedan due to the weight. VTA cars are pigs. 1550 grams!
I am using the kit setup. You can see in the following video that the car turns really well, the back end really swings around, making the car turn really easy. What do you suggest I do to smooth the car out. I would love to be able to just lay on the throttle the entire time. we are only running FDR of 6.9 with 25.5 motors so speed is not an issue. Here is the vid. One again I qualified 2nd and managed to get in the lead only to blow it by being too twitchy. I find the size of this track to be fun, but difficult to be "nice" as it is hard to get around traffic, the cars are so evenly matched.
+ YouTube Video | |
+ YouTube Video | |
#3829
I'd be tempted to try dropping one tooth on the pinion for the TC.
#3830
Grip roll can be reduced by some of the following;
Higher front roll center at the wishbone.
Narrower rear track
Wider front track
Softer springs.
#3831
Hey guys looking for some after market drive cups for the new gear diff and I use the 50 mm ecs up front... I hear the spec r are a little longer and allow the bone to sit in the cup more???
Anybody have suggestions and where I can find them in stock???
#3832
Yeah, I am not too concerned with it but thought I would ask. It is a little quick as the back comes around and I need to reduce speed in the corners a bit. It is fun to throw the car to the inside lane and pass when a gap opens. Yeah, they are SLOW, but the class is a ton of fun. There are times when you can go two wide around the entire track with no bad bumps. Very close racing. Can be tough though as it teaches patience as you must file in line behind the slower cars and pass when you can. I am guilty of pushing my way around the track but as i get better hopfully so will my track manners.
Would a softer roll bar help, I have some of those on hand. I though of moving the rear roll bar out to the outer set of holes to try that as well, or was it in?
#3833
___________
Spammy
Team R/C Plus
#3834
Xray make some steel gear diff outdrives. http://www.redrc.net/2011/11/xray-t3...rive-adapters/
XRAY also have steel outdrives for the spool, similar to the above for the gear diff, but the sidepieceracing ones grab more of the blade.
#3836
#3837
http://www.rc-mushroom.com/product_i...ducts_id=23514
XRAY product # for the steel diff outdrives: 304971
XRAY product # for 3.5mm blades: 305241
It helps to use the product numbers when googling.
#3838
Try the wishbone roll centre holders as they were supplied with the kit.
Either run all the +0.75's at the front (try that first), or possibly anti-squat, which would be to have the 0.75mm difference between the RC holders at the front of the front wishbones and the rear of the front wishbones.
Those two options won't cost anything to try as the bits come with the kit
#3839
I don't think roll bars would be the best choice as you'll start to lose the balance front/rear and some turn in.
That is for the traction roll right? Any advice on the VTA? I have some softer and harder roll bars that came with my car. I'd have to look at what I have. I do know I have some softer fronts (1.3).
#3840
