Xray T3 2011
#3812
Thanks Xpress, I will give that a shot. Yeah, I may have to go up a hole on the horn to get a little more throw as I was at full end point and still have room to grow so to speak in that direction bofore hitting the c-hub.
#3813
My EPA's are 86% one way and 88% the other.
#3815
Something else has occured to me.
Are the steering links the same length?
Check the front toe to ensure you are allowing the same amount of movement each way.
I would also put the link back into the centre hole on the servo saver, and try to get it on a spline as close as possible to vertical, mine has some right trim on the radio to make it vertical.
#3817
I use the metal sheilded ones, alot easier to clean than the blue rubber sealed ones, just spray with motor spray, dry with compressed air and relube with light lube of choice.
#3818
The standard bearings are ok, but as soon as they start to wear, replace them wth ceramics. you can get a full set for around $60 but can spend a whole lot more. I find once you start pulling and prodding at the blue rubber seals they bend and introduce drag into the bearing. Dont bother replacing with the xray branded bearings, you can replace them with much better bearings for only a little more in price.
#3820
#3821
Xpress is correct, the relationship between the link and servo horn is vital. The relation between servo horn and chassis is not relevant.
Start at the outmost end (steering links) and work your way towards the servo, not the other way round.
#3822
Has anyone tried the 2011 with a 2012 topdeck? I guess the topdeck would fit but I'm not sure.
Should a 2012 topdeck compare to a cutted 2011 topdeck? I'm thinking of testing my 2011 with my friends 2012 topdeck and then decide to cut my topdeck.
#3823
The '11 top deck if cut near the rear, will have a longer gap to the join between it's sides than the T3'12.
Put the two side by side and you'll see what I mean.
#3824
Thanks! Do you think the rear end will have too much flex?
#3825
