Like Tree5Likes
SC10 4x4 Thread
Old 12-09-2011 | 07:57 PM
  #12241
Originally Posted by Cameron Kellogg
I tested a truck set-up with a perfect 50/50 weight balance ready to run with the body. It took 5oz on the nose and I had to remove the rear bumper completely to do it with my set-up. It was not great under heavy braking corners because the rear tires would leave the ground. But it did jump and land good and powered through corners better. The rear would break out real quick if going into 180 corners if you stabbed the throttle too soon. Kind of a wicked tail whip. It might have been real good on a larger outdoor track but the tighter indoor track not my first choice. Adding the rear bumper and only 2oz on the front has the best feel right now.
I am working on scaling my truck right now... With a stick pack forward the truck its about 5oz heavy on the right and the front is looking to be about 9oz light.
I do see the how the back would break loose if it was equal all the way around. I'm going to try to equal out left and right but leave the back about 52-55% heavy.
Kbmoss is offline
Old 12-09-2011 | 08:12 PM
  #12242
vito's Avatar
how hard are the sway bars to mount up ?
vito is offline
Old 12-09-2011 | 08:13 PM
  #12243
Cameron Kellogg's Avatar
That comes to 107% total
I have my truck balanced left to right already. That took an extra 1oz. mounted on the left nerf bar to make that happen. That weight in not included in my extra added weight.
Cameron Kellogg is offline
Old 12-09-2011 | 08:17 PM
  #12244
Chad Smith's Avatar
I am running a High Tourqe slipper pad on the inside of the spur and 2 standard pads in the basket. What are you guys running pad wise with the basket?
Chad Smith is offline
Old 12-09-2011 | 08:19 PM
  #12245
CoyoteSlash's Avatar
I whip my backend out tight into the corner and blow right by the Losi's who have to use the embankment on the larger tracks. I love driving this thing hard intentionally tail whipping. I've learned to control it pretty effectively with Kid's actually wanting me to keep taking the same corner so they can watch it do the "full size Trophy Truck drift" - all the guys sigh at me and laugh. It's fun.
I've gotten it down to a science outdoor and don't lose that typical speed loss in a "bad drift" but I'm sure i'd look like an idiot at PRCR.
CoyoteSlash is offline
Old 12-09-2011 | 08:20 PM
  #12246
Chad Smith's Avatar
The instructions are not the best but they are not hard at all.
Old 12-09-2011 | 08:21 PM
  #12247
vito's Avatar
thanks they come with paper work lol
vito is offline
Old 12-09-2011 | 08:22 PM
  #12248
putting those Balls into the arms... Is:
Hell.
Then make sure you slide the bars through the balls before you mount them on the housing, and you're golden. You'll see what I mean.
Old 12-09-2011 | 08:26 PM
  #12249
vito's Avatar
thank you all the guys fro the help now. iam saving up for this kit and right now iam at 70 bucks on monday i hope to have a 100 . and by the frist of the year.
vito is offline
Old 12-09-2011 | 08:33 PM
  #12250
How is that 107%? How can you ever have over 100? You add weight you change% you may want to re scale your truck agian and not use that new math
When I scale I use total left vs right And total front vs rear, no need to cross weight a off road truck. when i said I would want 52-55% heavy in the rear I ment that the rear of the truck would carry 55% of its weight tripods the back. Do if it was 1000 grams the back would be 520 to 550g while the front would be 450- 480g.
Kbmoss is offline
Old 12-09-2011 | 08:41 PM
  #12251
Resqnu's Avatar
Default Body for SC10 4x4
Which body do you guys run? Do the new hi flow bodies make a difference jumping?
Resqnu is offline
Old 12-09-2011 | 08:49 PM
  #12252
symmetricon's Avatar
Originally Posted by IRM616
HV?
High Velocity Racing batteries 6000mah 60c.
http://www.rctech.net/forum/electric...rds-lipos.html
symmetricon is offline
  #12253
Adding that together, when misread, the front-rear ration assumption. It equals 107%.
misread as:
52% front +
55% rear +
=107%
Old 12-09-2011 | 08:51 PM
  #12254
I see, i run large 1/8 scale tracks. i can see where your comming from.
Old 12-09-2011 | 08:52 PM
  #12255
JEFFs SC10's Avatar
I have a dumb question. I've never used saddle pack batteries before.
Do you charge both at the same time? I'd really like to try them if it will give me a good edge and makes a noticeable improvement.
JEFFs SC10 is offline
