Tire Glue?
#16
Locktite professional grade CA hands down for me. Not the gel either. the thinner the better so it flows around the bead. Have never hade a tire come loose with this stuff. Tire and rim prep are essential. I use a combo mixture of water, dish soap(two drops) and rubbing alcohol(4 tbs) mixed in a small 1qt garden sprayer. Get a small wire wheel for a dremel to burnish the rim after cleaning and you are set to start glueing. Rubberbands! make sure you use them.
#17
Ive always used the Losi Tire Glue and it works well for me. It also comes with a very tiny straw type thing so it makes the job even easier.
#21
Thanks for all the tips guys, I'm definitely not going to have problems gluing tires now. We ended up using "Dr. Bond" and it glued fine, had no problems and I don't see any happening that are un-ordinary.
