Go Back  R/C Tech Forums > General Forums > Rookie Zone
Touring car opinions >
Like Tree4Likes
  • 1 Post By IndyRC_Racer
  • 1 Post By Techno Duck
  • 1 Post By GerryH
  • 1 Post By Hullen
Old 02-24-2022 | 04:12 PM
Default Touring car opinions
I am getting into on road and was wondering what is a good car to start with without breaking the bank.
Donc is offline
Old 02-24-2022 | 04:43 PM
XPRESS probably offers the least expensive well sorted cars.
the defacto answer (for good reason honestly) is to see what people are racing where you plan to, and by a used variant.
Maven is offline
Old 02-24-2022 | 04:46 PM
IndyRC_Racer's Avatar
This question gets asked frequently on this forum. The short answer is to visit your local on-road track and find out the popular classes are before you purchase anything. If you already have a class in mind, please let us know and we can steer you in a general direction.
OffRoadJunkie likes this.
IndyRC_Racer is offline
Old 02-24-2022 | 05:55 PM
OffRoadJunkie's Avatar
You should also add how much you are willing to spend. Some banks are bigger than others.
OffRoadJunkie is offline
Old 02-25-2022 | 08:38 AM
The 3Racing Advance S64 is a good choice also. Available for less than $120. Check RaceVTA or TQRacing.
Hullen likes this.
Techno Duck is offline
Old 10-28-2022 | 05:58 PM
What's the difference between a 3racing S64 / Xpress Xq2s vs Mugen MTC2 / Xray T4/X4 / Yokomo BD11 / ARC A10.
How much better is a $650 kit vs a $150 kit
Clearness is offline
Old 11-14-2022 | 06:43 PM
The difference between the budget kits and the high end kits usually comes down to fit/finish, materials used, ease of maintenance/tuning and support.
The high end kits use carbon fiber or aluminum for chassis and shock towers where the budget kits will use FRP. The quality of the plastics are usually better on the high end kits.
The budget kits can be very competitive at the club level in the right hands. Most of the time build, maintenance and setup can really make or break a car's handling, regardless of how much you spent on the car. A properly built/maintained/setup budget car will run circles around a poorly built/maintained/setup high end car.
On the other hand, there can be a lot of frustrations with the budget cars. Sometimes the instructions leave a lot to be desired. The fit of parts can be very frustrating during the build. And I do think there is a durability difference as well. If you are racing outdoors without walls/pipes close to the track, durability is probably not an issue, but in tight indoor carpet layouts, you might see a difference in durability.
These are only my opinions and they are worth exactly what you paid for them!! :-)
0010 is offline
Old 11-16-2022 | 10:53 AM
GerryH's Avatar
When I started racing, I went the cheap route buying a used RTR touring car. The car wasn't good but neither was I, so it was fine until I became a better driver. At the time I didn't want to invest in something like an Xray because it was expensive toy for me I was only using ~10 a year.
Some of the 3racing kits look very good. I've never personally raced one, but I know several guys that have. As 0010 said, the durability can sometimes be less out of the box. So research the specific kit to see if there's a weak part/design and upgrade or aftermarket parts to fix.
Also nothing usually wrong with buying a used kit from a name brand. I'd strongly suggest you tear the whole thing down and rebuild it to make sure everything is correct.
Chozwoz likes this.
GerryH is offline
Old 03-16-2023 | 08:04 PM
Get an Xray T4 2021, you won't regret it.
raydengt2000 is offline
Old 07-20-2024 | 11:32 AM
Hullen's Avatar
R/C Tech Elite Member
Default I think 3racing would be a top choice
3racing has great product support, parts availability is plentiful and cheap and they will are very competitive with RC’s that cost 4x as much(xray, awesomatix). I advise you not to start out with an Xray because it will be quite a learning curve and parts are a lot more expensive.
MonkeyCmonkeyDo likes this.
Hullen is offline
Old 07-21-2024 | 01:34 AM
Roelof's Avatar
Last week I could take a look at the Serpent X20 RTR next to the more expensive race version. The whole car is basically the same but most build with cheaper materials so over the time you can improve the car if needed. I also have an eye on it for just some fun on the track outside noise hours and just sell the electronics (to make the buy much cheaper) and put in my own stuff.
Roelof is offline
Old 07-21-2024 | 05:58 AM
MonkeyCmonkeyDo's Avatar
The cheaper 3racing and xpress are both good options.
d
MonkeyCmonkeyDo is offline
