So I have a T-300 brand new out of the package on throttle/brake duty in my D817T. The servo is not acting proper. It will just randomly stop moving, but bumping it with my hand brings it back to life. From neutral, it will never go to brake, I have to give it throttle, then go to brake from there. Swapped the throttle and steering servos around, problem followed the tekin servo. My radio is a Sanwa M12rs with RX-482 receiver. Is there some magical hoopla that I may have to change in my radio? Or how bout if finding someone with a hotwire, is there anything that lil thing can do for me?
Mickey B, do you still live in Corpus? If so, you race at Bill Witt? |
Originally Posted by RePeTe
(Post 15339594)
Originally Posted by brian mills
(Post 15339669)
Do you have your radio response mode set to SSR,SHR,or normal? |
(Post 15339926)
I have tried all 3 modes. it does the same thing in all of them
What Tekin servo for the Tekno ET410? I am thinking 190, and it needs 200 oz inches of torque according to Tekno? The steering on the ET410 is stupid fast. A fellow racer absolutely loves this servo!
(Post 15340045)
Be sure to perform a re bind procedure after switching response modes or it actually doesn’t change modes. If you have done this I would most likely contact Tekin for customer service |
and?
(Post 15339594)
(Post 15340549)
yea, that was done aswell, no change. probably just gunna have to send it back
(Post 15339594)
Mickey B, do you still live in Corpus? If so, you race at Bill Witt? Also, the splines on these servos are horrible none of my aftermarket horns will fit on them. I have to hammer 🔨 the horn on and then they are impossible to take off. When I tried, I end up scratching the case really bad. Its so bad I don’t want to run them, which really sucks cause I like these servos. |
What brand of horns have this issue? I've used the Tekin ones of course, as well as tested fitment of the AE, TLR, and others without issue. Granted some are snug, but you'd want that to be the case compared to loose.
Originally Posted by Mickey_B
(Post 15345746)
Originally Posted by Randy_Pike
(Post 15347737)
yea, it was hard to get the alu horn that comes with the servo on and off. But I don't mind the tight fit.
(Post 15347737)
| All times are GMT -7. It is currently 12:10 PM. |
