Tekin Hotwire 3.0 Bluetooth Thread
#186
You can only do software updates on PC or device with windows and a USB cable. We do not allow software updates for esc with Bluetooth connection with mobile devices, but interesting idea for PC with bluetooth. Currently there is no where in the windows program to connect with Bluetooth.
#187
Hotwire
#188
My HW 3.0 will not bind to my Pixel 5. Ive tried everything. First off the directions say to power on JUST the ESC, but when I do, no lights come on on the HW. I have to have my transmitter turned on to be able to get the blue flashing light. Aside from that I hooked up the ESC via USB to my PC and downloaded the software. Everything worked fine on PC via USB. First, I updated the FW, then I changed my setups to 3s and 7.4v BEC, then I made sure "Fan always on" was selected. After saving settings I re-calibrated the ESC and attempted to pair BT once again and it still doesnt work.
#189
One of the issues I ran into with one of my configs is that BT won't connect while my receiver is connected to the ESC:
Might try disconnecting the receiver and see if BT binds and connects.
#190
#191
I purchased a hotwire BT. I have both a RSX Pro and a RS Pro BE. I can Bind the Hot wire (it says bind successful) but each time with either speed control it can't find. My trim is in the middle and locations are turned on in my Samsung Galaxy 9 .......it just says "no hotwire bluetooth found. I can use it with the cable to PC but I already had a hotwire for that . I bought this one for the bluetooth feature.
#192
R/C Tech Elite Member
#193
Also note that due to some unknown .net framework procession of updates along the way windows 10 may have lost its certificate for HTTP activation and selecting 3.5 may not install properly however under that windows features on NET framework 3.5 the selection can be branched out and select only NON-HTTP activation.
#194
280 vs. 276 Firmware
I updated my RSX Pro to 280 and of course I lost the ability to use the Hotwire via Bluetooth. I didn't catch the disclaimer.
1. When do you think the app will be updated to work with 280?
2. Am I OK to reload 276? I am guessing it is OK to go back a software level since it still shows on the site.
