Hobbywing wifi issues >
Like Tree1Likes
Old 05-21-2017 | 07:25 AM
  #16
rctazmanmc's Avatar
Finally got it to work.
2 days of messing but works.
I at least got two of my speed controls updated.
rctazmanmc is offline
Old 05-21-2017 | 09:30 AM
  #17
dan_vector's Avatar
Nice one. Hopefully now you can see the benefits of the wifi link. I love mine.
dan_vector is offline
Old 05-21-2017 | 09:32 AM
  #18
rctazmanmc's Avatar
It boiled down to the having the wifi linked at the right time and connecting with the esc.
Once i finally figured it out I could see where the instructions need some better polishing to be understood better.
So far I like it - everything works and updating was sucessful. Just have look into the best adjustments on the speedo for brake and throttle settings.
Old 05-22-2017 | 06:32 AM
  #19
dan_vector's Avatar
Yes. For me it's get the esc with wifi link all powered up first before attempting wifi connection from the device. Then it's worked every time for me.
Old 09-15-2017 | 05:44 PM
  #20
My issue is a little different, mine connects and can adjust esc settings no problem but everytime i try to enter the firmare update part of the menus, the app just crashes everytime
any thoughts??
rcpowerz is offline
Old 09-16-2017 | 03:56 AM
  #21
rctazmanmc's Avatar
any thoughts??
From mustangkillaz
"I suggest talking to the cobraracing fellow on here if needing tech support for hobbywing. He's very nice and professional and seems to go out of his way for the right folks. It's too bad we can't have him here in North America. I believe he's directly involved with the factory and Can be a strong resource for any of you having trouble. "
Old 04-13-2018 | 08:03 AM
  #22
I'm having trouble with this as well.
I cannot connect when I press on the ESC in the top right hand corner.
I have already renamed the wifi, changed the password as instructions state.
I've reset it and still no luck.
Even followed the suggested troubleshooting steps that pops up when it displays unable to connect to esc, still nada.
Its a brand new unit too. Blah
ESC and wifi link get powered up first then I try connecting, still nada :-(
Evoking1230 is offline
Old 04-13-2018 | 01:37 PM
  #23
Joel Lagace's Avatar
You are sure your phone is not connected to home WiFi or track WiFi when attempting to connect to esc? Your phone will default to the better connection when given two choices... And internet connectivity is what it rather . At home I have to disconnect from WiFi to connect to WiFi module
Joel Lagace is offline
Old 04-13-2018 | 07:19 PM
  #24
Yes, it is connected to my now renamed Wifi Express.
Since its a older SCT Pro, maybe the ESC needs a firmware update? But I have no way to do that. I would have to get a program box and download the usb link software correct? (been reading up on the issue)
I was able to set the ESC the good ol' fashion way lol.
Old 04-16-2018 | 10:52 AM
  #25
Well, 3 days later and after looking at more than 1/2 of the Hobbywing Tech Support thread, I found the culprit.
I disconnected the ESC from the receiver, then booted up the ESC, then connected to the Wifi link via Wifi and what do you know....it connected :-D
yay go me lol
Old 01-15-2020 | 05:52 AM
  #26
colcan's Avatar
Default My wifi module does not turn on
Hello, anyone has had any issue like this. At the track my wifi module didn't want to on. I tried on 3/different esc but I couldn't make it work. Any help would be great. Thanks
colcan is offline
Old 01-15-2020 | 07:15 AM
  #27
Bsthetech's Avatar
R/C Tech Elite Member
1) Turn on radio, Turn on ESC, plug WiFi adapter in to ESC ( in that order). Works for me every time using a buddies adapter. Plugging the WiFi adapter into the ESC before power caused it to fail every time. YMMV.
2) Change the SSID to one you’ll recognize as yours, not the guy’s next to you. Might as well change the passcode too.
Bsthetech is offline
Old 07-22-2020 | 12:15 AM
  #28
MurderPony's Avatar
Well... I had the same problem and your advice worked somehow. The strangest manual I ever saw, lol. Thank you.
MurderPony is offline
Old 10-25-2020 | 04:40 PM
  #29
rraden's Avatar
Anyone run into a problem where the Hobbywing Wifi module stops communicating with the esc after latest IOS update? My module always connected without issue until recently. Now it won't connect with any of my esc's. The only thing that has changed was the installation of the latest IOS software on my phone. The wifi module still generates a wifi signal so my phone connects with it but when you try to connect to the esc it thinks for a minute and then does nothing. The latest IOS also indicates the Hobbywing wifi signal has weak security. Never indicated that in the previous IOS software. I've tried everything I could think of, resetting the wifi module (several times), removing and reinstalling the HW app, and updated the esc to the latest firmware. When I hooked up the esc's to the PC everything worked fine. Any suggestions would be appreciated.
rraden is offline
Old 11-06-2020 | 11:58 PM
  #30
i was having the same problem, my friend figured it out after we were having problems with our POS system after doing the update for the POS iPad. You need to go into “ settings “ on your iPhone, choose the Hobbywing app and then make sure the option for “ Local Network “ is turned on, It will solve your problem.
Medicinal Coma is offline
