Tekin Rx8 Gen3 Thread
#318
I asked this question in the Gen2 thread but you Gen3 guys might be able to help.
"Just brought a RC8B3e that came with a Gen2 RX8.
Question is about the cooling fan. It starts when you power it up but after about 5 seconds it shuts down, normal?
Most other ESC's I've used the fan just runs start to stop but does this start and stop as needed?
I haven't actually run the buggy yet to see what the fan does over the run, thought I'd check before hand."
#319
The iOS version was just recently sent to the team for testing. I'm not sure how long it will take until it turns up in the App Store, but my guess would be 2-4 weeks.
#320
Issues with rx3
First of all I would like to say that I am extremely excited with this esc. I have tried Orion and hobbywing but this makes my e817v2 go smoothly like a nitro. Just 2 issues that I can't seem to get rid of. After ta fullgood throttle at the straight, when I apply a quick full brake the ESC automatically brakes more after I release brake and pulls the throttle. It really destroys my entry in the next corner. I can't seem to get rid of it. Which setting is it that makes it so?
also I am having trouble with connect with my android phone to the hotwire Bluetooth. I am now using an old iPad for that. The hotwire app from gplay can't do the trick. Any fix for that? Also I am not running with sensor able since I can't fit it in the hot bodies e817. The space between motor and ESC are too narrow and will crush the contact.
Thanks for any advice.
#321
I am experiencing something very annoying. After a runs down the straight, full throttle as I apply quick hard brake and then pushes throttle again the ESC brakes as I pull the throttle lever making it very difficult to take corners after a high speed straight. What setting am I missing out on? It almost locks up! Very heavy brake.
I am running tekin rx8 gen3 with tekin 2050 gen 3 motor. No sensor wiring. This stuff is the best I have tried out of any castle, Orion, or hobbywing combo have tried yet. Too bad I had to import this to Sweden. Or lucky me, cause this gives me a big advantage on my races. ��
#322
And buy a sensor wire. This motor/esc is even better with the sensor wire installed. I have driven my combo 1 day without sensor cable because it broke and I didn't had a spare. While it worked, the throttle lagged a bit and it was hard to time jumps. With the sensor cable, this is much easier to time.
#323
#324
I have install the new Hotwire PC application, but I'm not sure how to update the Hotwire device. I can only choose firmware version 272 for my RX8 V3.
I thought 276 should be available by now?
#325
I agree with Morgoth and recommend using a sensor cable. The only setting I can think of that might make the motor feel like its braking when you get back on the throttle is Active Drag. If you don't have that or Active brakes enabled, I can't think of any settings that would make the motor continue to brake when you get back on the throttle.
#327
From what I've read on those servos, it is more of a disclaimer than anything. They don't want to be held responsible for damaging the BEC in your speed control The BEC in the RX8 Gen3 is rated at 5.5 amps, which is much higher than the typical BEC. I don't think you need to do anything special to use that servo.
#329
Everything is OK now!
But the iOS app is a bit buggy now It doesn't preload the values anymore in the overview screens and when I try to make an adjustment, my current value is a bit off screen and it's not very clear. I'm using and iPhone XS Max. Not sure if other phones have it as well?
#330
Nvm, I should sleep a bit more. I saw only V276 and not V272 as I thought first.
A fresh version of the iOS app should be out very soon. Hopefully this fixes those glitches?
