Brushless timing question.
Can anyone tell me how much rpm goes up per degree of timing ? I'm looking at putting a hobbywing 3656 3400kv sensored in my wraith. I have ran the Traxxas vxl before and I know I want more speed than that and its 3500kv. I want the low and slow of the 4 pole and lower kv also sooooo. I'm wondering if I run low timing then boost or turbo ? Will it make much difference? I can either run a skyrc toro 120a which obviously has boost and turbo or run a brushless hobbies 120a which has just timing. Unless a firmware update ads something to the adjustments available. Right now im running a 3656 4000kv non sensored with 0 timing and its pretty smooth but if loaded heavy it'll cog but top end on 2s is nice.
nah, you don't need one of those for what you're looking for here. trial and error. check temps frequently.
when i ran 4wd SC, i ran a hobbywing 3656 4000kv and a hobbywing V3 speedo. most people were using the 4700kv version. i liked the 4000kv because i could tune it with boost/turbo to be as fast as the 4700kv but more driveable on the infield. when i'd run a track with a long straight, i'd run more turbo. big jumps with short run ups? more boost. for your application, i'd put that toro in there and experiment with boost/turbo, again, checking temps. once you get a feel for what each does, i think you'll like it.
