Reduce cooling fan speed >
Like Tree1Likes
  • 1 Post By howardcano
Old 02-16-2017 | 01:21 AM
Default Reduce cooling fan speed
Hey guys. Picked up a yeah racing tornado cooling fan at my LHS but when hooked up to my esc it's crazy fast and loud. It's a 5v 0.28a fan and the 6v 1.5a I'm feeding it is way more than I need. Can anyone suggest an easy way to cut the voltage down? Resistors?
jonnymorrow is offline
Old 02-16-2017 | 03:24 AM
gigaplex's Avatar
A resistor would be the easiest option. To drop it down to the rated 5V, you'd want roughly 4-5 ohms.
gigaplex is offline
Old 02-16-2017 | 04:35 AM
disaster999's Avatar
Regional Moderator
RCmart did It did say the fan is rated for 8.4v 2 cell lipo power so I dont believe your feeling it way more than it needs. As it being too loud and crazy fast, as long as it can effectively cool your ESC/Motor, I wouldnt worry too much about it. You wouldnt be able to hear it once your car is on the track
disaster999 is offline
Old 02-16-2017 | 04:50 AM
howardcano's Avatar
Having a very loud fan can be a good thing. If you notice it has failed during a run, you can pull off before overheating the motor.
sakadachi likes this.
howardcano is offline
Old 02-16-2017 | 09:30 AM
Yeah it's definitely obnoxious. Def need to reduce voltage. Besides my motor doesn't get crazy hot. Just need average cooling.
Gigaplex, just one resistor across the hot wire? (Red)
Old 02-16-2017 | 11:43 PM
gigaplex's Avatar
Yes, just a single 5 ohm resistor in series with the fan. 10 ohm resistors seem to be easier to source, if that's all you can get, you can put 2 10 ohm resistors in parallel to get 5 ohms, then put that unit in series with the fan.
gigaplex is offline
