New Sanwa MT-44 4-channel 2.4GHz radio system
#241
I just got Samsung 30Q 18650 3000mah Batt to try.. But I can't seem to charge more than .5 Amps at 1s Lipo or lion mode on my icharger...
After charging it for a long time it took about 700mah but when I plug it in, transmitter beeps instantly with "low voltage"
I have switched it to "lipo" mode under "BATT" on the transmitter.
Am I missing something or this Batt is no good?
TIA
TIA
#248
Is it possible to change steering wheel angle on MT-44? Does M12 steering wheel angle adjustment part fit for MT-44?
#250
First night with the MT44. I swapped 2 of the 3 cars that I was racing from the M12S to the MT44. Its similar enough that I still haven't cracked the book open but at the same time it was complicated compared to the M12S. It took me a full round to get use to it. When I got to my third heat it took me a couple of laps to get use to the M12S again. I honestly didn't think that I'd notice the latency difference but I did. The MT44 is definitely light and compact. It feels pretty good in my chubby hands. Overall I'm borderline disappointed. Its not much of an improvement over the MT4S. Its still an excellent mid level radio but I was hoping I'd like it more. In fact I thought that I would semi retire my M12s and use the MT44 for club racing but I'm not so sure now. If your budget is in the $300 range then its top of its class. The fact that it comes with the 482 RX says a lot. If you don't have a budget then I'd recommend the M12S.
#253
ah man. i was hoping this would have similar response to my vanilla m12.. i like my m12 but not enough to replace it with another one. the size and weight of this is attractive as i dont use any of the extra fiddly stuff of the m12. just wanted a fast radio.
im sure this would be awesome for nitro maints though.. i still wonder if id notice the difference with ultra fast servos..
#254
It is of course possible that there could be some delay in the transmitter before the data is sent over the RF link, and this could be different between the M12S and MT-44, but I also tried a high speed camera capture of the same receiver and servo connected to an M12S and an MT-44 and found them to offer identical performance according to that approach as well.
#255
Do you guys think i would like this compared to my current m11x? Is this radio faster than my m11x? I'm not sure if I should get this or pony up for the m12. I assume it has a place for a neck strap?
