Charging a 3s Controller battery. Help >
Old 09-19-2016 | 04:25 AM
Default Charging a 3s Controller battery. Help
I just bought an Airtronics M11. Came with a 3s, 2500 Mah Lipo. I cant charge it as every time I try the charger says I have a broken connection. I can only plug in the lead to the balance board. Doesn't seen to be a way to get power into the battery.
I was told to plug in the thicker lead to the balance board to charge. Didn't work. How can I charge this battery? Any suggestions?
Thanks in advance!!
Battery is Turnigy 3s Lipo, 2500mah 5c.
Miko1976 is offline
Old 09-19-2016 | 06:58 AM
Roelof's Avatar
Take out the battery, there should be a balance connector and a power connector.
Roelof is offline
Old 09-19-2016 | 08:12 AM
Thanks in advance!!
Like stated above, remove battery from radio and then the power connector goes to the charger and balance board to small balance connector. Charge at 1C. (2.5 amps)
Andy Koback is offline
