End bell timing no effect
I have a trinity 24K 17.5. it ahs been a rocket running about 50° timing
and 160°F at end of heats.
Took it apart and cleaned bearings etc. put back together now changing the end bell timing has no effect on the motor at all. No matter where I set it Ionly pull 1.66 amps with fresh battery and no pinion.
Any Ideas.??
Any Ideas.??
+1 on sensor problem. Maybe the shims weren't put back correctly on the rotor and the sensor isn't detecting the magnetic field properly or something is parasiting the sensor. Do you have a sensor checker ?
I would check the way you reinstalled it. On my d3.5 8.5t motor I did the same thing. Then I took it apart again to find a shim I put on the wrong side of the sensor board. Its the shim the screws screw into. Looked like a half moon.
