Sensor wire question? >
Old 06-18-2016 | 07:17 AM
MeasuresMicrons's Avatar
Default Sensor wire question?
Getting ready to link/calibrate my HW XR8 ESC up, my sensor is a bit short. Can I set the system up and run it then add the sensor wire later, or should I just wait until I get the longer wire? Sorry if this sounds dumb....but BL is new to me, came from Nitro. Thanks
MeasuresMicrons is offline
Old 06-18-2016 | 07:48 AM
Roelof's Avatar
If the ESC can run sensorless then yes, it is no problem.
Roelof is offline
Old 06-18-2016 | 08:13 AM
Thanks man.....It can run both. I just didn't know when calibrating it whether I'd have to re-cal it for the sensor wire or just plug it in. Thanks.
Old 06-21-2016 | 06:59 AM
Recalibration will not be required..
Sensored driving only changes the way current is supplied to the poles of the motor at low rpm's..
Bartje81 is offline
