New Spektrum Radio DX6R
#1576
If you aren't sure you want all the Android stuff --- DX5R is right there.
#1578
Like lowspark mentioned - DX5R is the 6R's brother in ergonomic design and function. Difference is no android. The DX5R is actually closer in functionality to the M12 - the 6R just gives more options to do things with the Android both for r/c and outside of r/c.
#1579
I like the feeling of the radio. Good stuff. Don’t think I want to lose my code 10 for it but nice radio
#1580
#1581
I doubt they are going to answer you. They have not divulged much info until the actual releases
#1583
They are correct, this question wont be answered and mentioning its the third time its been asked makes it worse, not better. When Nick can talk about it, he will.
#1584
Good manners don’t cost much!
#1585
Hi,
Just got a DX6R and notice a few things,
With the throttle servo direction reverse, the trigger sense in the telemetry screen is backwards.
In the telemetry setup menu I can't set the temperature scales max temperature. If I try to enter something the field goes blank and no input is accepted.
Is there a way to change temperature units?
Is there really no RX strength telemetry?
The radio is all updated and running 2.01.01 FW
I found it disappointing that the set did not include the temperature and voltage sensors that normally come with the SR6000T.
Joel
Joel
#1586
Future updates
Ive been seriously considering purchasing the DX6R in the near future. With that being said, I've got a couple questions... What are the plans (if any) to update the android hardware on future devices? Just curious, as it looks like this model is around two years old. Has the issues with the chincy SD card cover been rectified? If not, what are your plans to correct this? It appears the cover issue was identified VERY early on, but I've yet to see, or hear about any corrective action to address it.
Thanks,
Thanks,
#1587
Another bug I notice, maybe related to the servo direction being reversed,
If using ABS, the pulses per second are backwards, setting 1 is 20, setting 20 is 1.
I tried to use a custom curve to get around the servo reversing thing, that did not work which is fine, when I set it back to standard curve, that was OK. After I rebooted the radio, it was back to using the custom curve, the radio said it was standard. I reset the custom curve to look like a standard curve and it's back to working but who knows what curve it really is.
The idle up feature seems somewhat broken. There needs to be a toggle mode for the momentary switches. The only way I see this feature being useful is to put it on switch I which is a bit awkward because of the 3 positions.
As far as signal strength, there is the RF indicator on the telemetry screen though as far as I can tell, it's just decoration. I haven't found a range test mode yet, so I put the receiver in a metal box and walked away, the scale never changed.
It makes me wonder if such basic operation things are broken after so many FW updates, what important things are broken that are waiting to cause a big problem.
Right now I think I bought another paper weight. I had originally bought a Graupner X-8e and found issue that just annoyed me. I was looking at the Futaba 7PX and was put off of it when I saw the cost of basic sensors. My guess is the Futaba would be well vetted.
It's shameful the lack of testing that is going on before these companies release a product.
I guess for now I'll keep using the X-8e, I don't like the FW much but at least I'm confident in its link.
Hi,
Joel
Joel
#1589
Thanks,
Thanks,
#1590
Scoobied -- used my 6R as the first test sample this weekend to test some updates (and it worked without issues), but as we have seen from the past, I want to make sure any updates jump through all the hoops before they get out to the public. My politically correct answer -- some stuff that you have seen mentioned on this thread is part of the update list. We saw it, we listened, we are updating it.
