Maclan Racing Products Discussion
#1441
#1443
Thank you again for the info guys. I did open up the motor and there was some solder inside which I cleaned up.
I will finish working on the car tonight so I can run it on Saturday.
#1444
Maclan FTW!
#1445
Anyone got some recent suggestions on FDR and timing ranges to start with on a 2wd buggy 17.5 blinky class I am all ears for the V2 Maclan. this will be running on primarily.
Going to do some testing this weekend, nothing serious but will see how the new software works relative to the using reverse issue. Will be running in sensored mode though.This will be on a Pico.
#1447
Anybody have their sensor port on their Max Pro ESC break off?
Had it for about a month and really like it but a bummer it broke already. Sent it in today and now just have to wait, since don't have another ESC...
#1450
#1451
In off road, you never can tell. All I can say is leave a little slack on the sensor cable and clean the pad where you plan on sticking the the esc down with motor spray so the double sided tape stick good. Im guessing during a wreck, your esc came undone and pulled on the sensor port.
#1452
some news on the reverse issues reported. With the latest software so far I haven't seen any cutout like before, running sensored mode.
Now, I need to try it at a larger track where I saw the cutout issue a lot.
The one thing I found odd in comparison to other ESCs in how they do reverse is that when you go into reverse, it gets the car to stop moving you had to basically treat the FWD direction like a linear "brake". It took some getting used to as when going then to FWD you would need to do a FWD pull again after using FWD to stop the car.
So the flow is like this:
FWD -> BRK -> STOP -> REV -> FWD (to get it to stop, linear response here) -> STOP -> FWD (to get car moving again)
I am thinking the main difference is on other systems when you hit forward while in reverse it goes to FWD right away and there seems to be more of a drag brake effect while in reverse when you left off reverse.
The maclan way may be a safer way to do it, just feels odd. Be nice if it could be a option to select how that response is setup.
#1453
#1454
Hi guys, it's the newbie again. Wanted to know if you can run your LIPO battery for 5-10 minutes, give it some rest and recharge it again 2-3 times in one day. I have a Maclan 6400 2s battery and two other batteries that I can use. Is there such a thing as overusing the battery and it becomes weaker? Should I at least save one good battery and only use it once a day for future races? Like to hear from people here. Thanks
#1455
