Eagle Racing MD2 Motor Dyno
#76
Just for your info, not attacking just passing along some info and asking a question. Other note, the Fantoms aren't produced anymore so they aren't competitors.
Just wanted to know if what he said was still applicable (probable). I still consider the info from both devices valuable. They work nearly identically and if I didn't have a Fantom already I would strongly consider this device.
In looking at the Eagle tree. I wonder if anyone has tried using a 12v car battery as the source instead of a pair of lipos?
#77
The Fantom developer was referring to his product and the discussion was a couple of years ago when I was converting it to do brushless motors (I didn't include that info). I do not know if he even knew about this product then.
#78
As I thought about this further, I suspect that the input is a parallel connection and that they feed battery voltage direct. With that said, a 12v source unless reduced would be a bad idea. But here is another option. Go to your local farm supply and buy a 6 volt lead acid battery (old tractors used them). Where it won't spin the motor as fast as a 2s LiPo, it would still give you comparable data to tune your motors with out battery state fall off. Afterall the Fantom powers the motor with 5v.
#79
The ability to use your own batts as the power source lets you test your power source - all the way from the battery to the motor. You can see the effects running different batteries on torque output clearly. I find this to be valuable I'm determining the condition of my entire power train.
Unless you are running 10 turn motors, you will not blow the 35 amp fuse that the unit is supplied with when running single lipos.
#82
If you want a consistent power source for the MD2 dyno
https://eagleonlineshop.com/eaglesho...spx?id=3800-P4
#90
For a power supply, Fantom used to suggest about 12v/120a that is why I use a car battery. You never have a amp or voltage problem. On a R/C battery (LiPo) a few pulls without a recharge and I think you would start seeing a difference because of voltage drop. But it would take testing to show how many before results are affected.
