EzRun Power Cut
Hi Guys,
My dad is running a 35A EzRun ESC. It goes great, but then all of a sudden the power will drop right off (as if the low voltage cut off has come on). If he waits a little or gives the car a nudge the power will return.
Any ideas?
Ryan
Any ideas?
Ryan
I had a similar problem recently with a different esc. The servo was drawing to much current overloading the internal bec and eventually the esc would cut out. Usually after 5 minutes or so. If I waited it worked fine again. What servo does he run?
Hi, I 've had several drives that mark and in some, especially depending on the battery, you must regularles cutting quite right lipo ( 3.0v , 3.2) , this may be due to low battery discharge ( C ) or a motor consuming .
Try cutting down lipo drive and see if it also takes a little more
