Like Tree31Likes
Futaba 4PX
Old 08-07-2017 | 12:25 PM
  #2296
Ok guys. here is a queston. Brand new out of the box 4px had glitching issues with the r304 receiver. replace receiver. now with different receiver the glitch is back and effecting more then just steering. had it glitch in a qualifier this weekend and almost cost me my off road vehicle. i need some help or advice. only having issues with the 304 receivers. Had to borrow a radio to compete in the mains this past weekend.
Chief88 is offline
Old 08-07-2017 | 01:02 PM
  #2297
CCristo's Avatar
R/C Tech Elite Member
What firmware is on the radio?
CCristo is offline
Old 08-08-2017 | 05:15 PM
  #2298
shows 1.3e on the screen
Chief88 is offline
Old 08-08-2017 | 06:30 PM
  #2299
CCristo's Avatar
Upgrade to the latest and see if that fixes the problem. One of the releases fixed the glitching problem, but unfortunately, I can't find the release notes on what version it was.
Futaba® Software Downloads/Updates
CCristo is offline
Old 08-12-2017 | 06:02 AM
  #2300
TAW
Has anyone seen an issue with the brightness adjustment like I am having in the linked video below? I picked this up used from a friend and it had v1.3 firmware so I updated to 1.4. I did not test this before the firmware upgrade.
As you can see changing the brightness doesn't seem to do anything but as I go down and up the entire screen's contrast changes up and down. May not be an issue and I am just wondering if others have seen it.
https://youtu.be/SzRho0JLGRA
TAW is offline
Old 08-24-2017 | 09:32 PM
  #2301
Is there any place i can get a larger diameter wheel for this tx? I went to the 4px r from spektrum and the futaba wheel feels to small in my hand
davidmann07 is offline
Old 08-24-2017 | 09:35 PM
  #2302
What I had done was install a Dirt racing foam . It's O.D. is a lot larger than Futaba's original . They are made by J Concepts either gray or yellow. I have the gray.
On another note, I had the opportunity to handle and fondle a 7PX. Man is it sweet! Just may have to get one. Maybe!
Raul Garcia is offline
Old 08-25-2017 | 12:07 PM
  #2303
Ok thanks ill take a look and ser if i can find one. I really want to trade it for a dx5r but cant get it sold
Old 08-29-2017 | 09:21 AM
  #2304
google 4px steering wheels and you should see several. can't remember who made mine
larc is offline
Old 09-02-2017 | 10:23 PM
  #2305
builthatch's Avatar
picking through this thread, i haven't seen it but then again this is a long thread!
i have noticed that the internal antenna receivers' specs say 230'/70m receiving range...but they don't have a range for the versions with an antenna.
i have emailed futaba but maybe someone else has already considered that the antenna version may or may not offer longer range (obviously, less interference).
builthatch is offline
Old 09-03-2017 | 12:53 PM
  #2306
Somewhere on youtube there was a test (4PLS) and signal loss was about few hundreds meters away from transmitter.
Macio4ever is offline
Old 09-07-2017 | 09:28 AM
  #2307
i also have been wondering if the antenna less receivers are working good? buying new radios and receivers after horrible experience with dx4r pro with signal loss and run away car's sure is nice to get rid of them if they work!!! i'm confused why the 204gf-e is cheaper then than the 614ff-e the fasst seems to be a "newer/better" technology? or am i way off here.
using it for 1/12,F1,USGT,PRO-10 is the 7px worth the extra $ if im only using 2 channels, no mixing, so s-bus or servo programming? just looking for opinions...
xps800doo is offline
Old 09-17-2017 | 04:03 PM
  #2308
Hi, sorry not a 4px question but I'm looking at the 4pv. I really like the feel of the 4px and 4pks in the hand and was wondering if anyone had held the 4pv and 4px and could comment on how similar they feel. I know it's subjective but I don't have access to a 4pv and would like to know if they're the same fit in hand, same trigger size etc. Thanks.
mackz is offline
Old 09-18-2017 | 09:19 AM
  #2309
jason cheng's Avatar
selling http://www.rctech.net/forum/r-c-item...-mint-new.html
jason cheng is offline
Old 09-20-2017 | 05:12 AM
  #2310
slodsm's Avatar
Now I know futaba says 70m, but I've personally ran mine well over 200m with no signal loss what so ever. I imagine the antenna version is as much or more. Never tried it with the 304sb, only the e version when I was screwing around at the house with my kid.
slodsm is offline
