DX4R Pro
#737
Super.
So, not only do my DSM receivers no longer work, my DSM2 receivers would only work on the slowest possible setting.
Next radio will be Futaba or Airtronics.
This version will disable all RF protocols except DSMR and DSM2-16.5m
#739
I went to the mt4s airtronics anny edition and it has more steering response and I know everyone says this but I actually do feel more connected to the car. I switched radio and rx only to my 1:10 2wd and my 1:8 ebuggy with no other changes at the time.
I can only imagine how nice the m12s is as that's airtronics flagship radio. Only downside is rx's r more expensive with airtronics
#741
Get the regular mt4s then it can be had for 199 or sometimes lower if ur lucky or coupons etc
#742
This past weekend I raced at a track that seems to have heavy signal saturation or some sort of interference. My vehicle would loose steering around the one turn almost every time. About 6-7 other Spektrums guys also had issues and there were several that didn't.
Any thoughts on what might be causing it and how to fix it?
Would a firmware update help?
#743
#744
#745
Also saw glitching at the old MRRC track in LI - but that affected other brands too..
Both cases have overhead cables pretty close by. But the fact that many of you had issues is pretty odd. Sounds like you tried another received and hence re-binded....Doesn't sound a specific radio issue, something environmental.
You using DMSR receivers or older DSM2 ?
#747
Yeah pretty odd. I've seen a couple of issues at T&L and the cars are very sensitive to making sure my receivers had good antennas (found out one of my 410's had a cut in the antenna and had to swap it out with another).
The weird thing is the glitch happened at the same exact spot on the track every time
#749
If the same glitch is happening for everybody at the same spot, regardless of where they're located on the drivers stand, then the interference is localized to that spot, or there's something between the driver's stand and that spot. EG: structural, electrical, or perhaps other systems operating at 2.4ghz, wifi antenna/booster, amateur radio)
If the glitch occurs depending on where you're standing on the drivers stand, there may be something in the stand or where you hold your radio in relation to it. EG: If I'm on the stand (it's made of metal pallet racking) I hold my radio low. Sometimes the vertical supports will block my radio signal at specific parts of the track.
If ther are no obvious physical/electronic barriers - Drivers stand is clear, open room with no supports, stone age electronic systems, then the fall backs are someone owns a cheap radio, or there's a black hole under the carpet.
That's all I've got and I'm switching to Sanwa, because I'm tired of this stuff.
1Likes
