Tekin RSX Thread
#739
Your help is much Appreciated!Cheers!
#740
#741
#745
I'm having the same clicking noise issue with my RSX. Tried a Tekin Redline and a Thunder Power motor and it still makes clicking noise. The only thing that helps is if I set everything back to default and run no boost, as soon as I put any boost in the RSX it makes that clicking noise. Randy said an update would be out to fix this, however when I plug my Hotwire into my RSX it greys out the the "advanced" box so I cant do any updates, what would that be? I updated to 2.0 on Tekins website but it did not help.
#746
Tekin is aware of the issue. You should be able to access the advanced menu.
#747
I know I should be able to, but the 'Advanced" box is greyed out so I cant click on it to get the advanced menu( when I plug in my older RS Pro it works fine and I can access everything). I have the older Hotwire interface, would this be an issue? I thought by updating of Tekins website would bring it up to date?
#748
#749
Thanks Casper decided to go this route just to try something different and am really happy with it used the Exotek waterfall shelfAttachment 1274683
95Likes
