Like Tree95Likes
Tekin RSX Thread
Old 12-05-2013 | 03:51 AM
  #181
tipperjackson's Avatar
Originally Posted by yzracer758
The RSX comes with 12awg wire and is what we would recommend for any 1/10 application.
Thanks YZracer. I was pretty sure it came with wire but wanted to get some trick pink wire or light blue so wanted to make sure I was ordering the right size.
tipperjackson is offline
Old 12-05-2013 | 05:48 AM
  #182
spu83's Avatar
Originally Posted by tipperjackson
I've got one of these ESC ordered. Sorry didn't have the time to look through forum. What weight wire does Tekin recommend for a 6.5 motor? 16,14,12 GA wire? They don't make any recommendation in the instructions.
Thanks Ron
My ESC is next to the 6.5 motor the wires are only 1.5" long and I use 14 GA wire but the battery wires are much longer so I use 12 GA.
spu83 is offline
Old 12-05-2013 | 10:49 AM
  #183
What is actually going on with the RSX are they going to be released any time soon ?
yunowill is offline
Old 12-05-2013 | 10:55 AM
  #184
Team Pink's Avatar
Most of us team drivers have been receiving ours over the past few weeks, so I would say they are really close to a public release. I know Amain Hobbies is still showing a mid December release as well as Tower. I'm sure Randy Pike would have more of a solid answer.
Team Pink is offline
Old 12-05-2013 | 11:15 AM
  #185
That sounds good . I had an RSpro that was brand new that I sent it for the RSX but I keep hearing there is delays on certain things and can really get a straight answer . I heard release will be in the New Year ? I just really want to finish the build on my new buggy and get it running with the RSX lol
Hopefully someone here can have a straight answer
yunowill is offline
Old 12-05-2013 | 05:42 PM
  #186
This is perfect. I'll get my new 22-4 and RSX at the same time, that way I won't have to mock up an rc car and pretend I'm building my new racer.....LOL!
Old 12-06-2013 | 03:30 AM
  #187
I've always had difficulty soldering 12gw onto the RSpro posts. I already pre tin and flatten the wire with pliers, the slots just seem too small for the 12gw to get a nice clean solder connection. Anyone have any other tips that I might be missing?
Thanks Ron
Old 12-06-2013 | 08:14 AM
  #188
dski's Avatar
Thanks Ron
Sounds like you're trying to shove the wire into the small post slots? I make a butt joint - don't squish the wire just pre tin each set the wire on top of the post and get a good shiny solder joint.
dski is offline
Old 12-06-2013 | 08:24 AM
  #189
TY@TEAMTEKIN's Avatar
Team Tekin
Thanks Ron
Like dski said above, you don't need to solder the wires into the slots, those are a solder cradle. On top is perfectly fine. Now on the RX8s, I do tin and squish the wires a little and they fit in those posts nicely. I use 12awg on everything.
TY@TEAMTEKIN is offline
Old 12-06-2013 | 09:47 AM
  #190
Thanks for the info. I had watched a video on how to solder Tekin RX8 and I had just assumed because the post where slotted on the RSpro just like the RX8 that the solder technique was the same. Your explanation makes more sence because the slots are so small.
Now come on RSX, time to be released.......
Old 12-06-2013 | 07:53 PM
  #191
ta_man's Avatar
Then again, if you really want it in the slots (but this was with 14 awg)....
ta_man is offline
Old 12-06-2013 | 07:55 PM
  #192
skengines's Avatar
Tekin posts are very easy to solder on to. I even soldered 10awg wire with no issues but I prefer 12awg.
skengines is online now
Old 12-07-2013 | 02:08 AM
  #193
Any news when the rex is going to start shipping ?
yunowill is offline
Old 12-07-2013 | 05:35 AM
  #194
Much cleaner looking than mine......LOL!
Old 12-07-2013 | 09:40 AM
  #195
Dusttt's Avatar
What is the ETA on these?
Dusttt is offline
