ICHARGER 308 Duo
#32
Is there a way to do minor adjustments to this charger if it reads say 8.38v at tech vs 8.40v? I thought that was an option to adjust how far it will charge up each cell, but I didn't find it anywhere.
I am using the Hitec ePower 30amp 12-18V 540w power supply with this charger. http://www3.towerhobbies.com/cgi-bin...&I=LXDAKK&P=ML
I did test 2 x 2s lipos at 30amps each. That is the Max the charger will go, but this power supply is not big enough for this. It does have enough power to do any combo of 50amps and that is more then enough for me! So it would do 2 x 25amps or 1x30a and 1x20a or in theory the combine both ports for 1x50amps, but I didn't try that.
#33
You want to look in the >120 page range. I'm not sure if they had an answer but I remember seeing something about it.
#36
The one above is rated 18v 540w.
#38
All you need to do is just adjust the charge end voltage. For instance, at IIC in Vegas earlier this month my packs kept coming off at 4.18 (charger was set to 4.20), so I upped the charger to 4.22 and packs came off at 4.20. Good to go.
#39
#40
Got mine tonight. This thing is sweet. I love the screen and how everything is right there without having to scroll around.
I did notice a discrepancy between the displayed full pack voltage and the individual cell voltages on channel 1 (total voltage was reading lower than the cells added up). So, I just went into the calibration screen and took measurements with a volt meter and adjusted to make them match. Cake.
#41
Just picked up one of these chargers and need help with picking a power supply.Will be charging 1s and 2s lipos.I have a muchmore 24 amp power supply and I think it should be enough.Any thoughts?
#44
I charged two 2S at 5A each with no issue. I don't recall exactly what the charger said I was pulling from the power supply but it was less than half capacity IIRC.
#45
When I typed all out I was thinking of a little more than 5A, rather the 30A capability of the charger. I agree, a pair of 2S at 5A would be easy for the 24A supply. Probably around 7~8A from the supply.
5Likes
