Like Tree5Likes
ICHARGER 308 Duo
Old 08-30-2013 | 09:39 AM
  #16
Originally Posted by Kebabkongen
So I have a Muchmore PS rated at 2x22A @ 12V, how much will I be able to charge with using this charger?
I would get a 24 volt powersupply if your going to charge two batteries at 2-3C each.
JiuHaWong is offline
Old 08-31-2013 | 12:39 PM
  #17
gotspeed24's Avatar
can anyone tell me where i can buy parts for my icharger 4010? i broke the little flat blue port peice on the front and need a new screen housing.....thank you... im in US
gotspeed24 is offline
Old 08-31-2013 | 02:10 PM
  #18
I'd be surprised if they sold individual parts for ichargers. However, if they did, http://www.progressiverc.com would probably be your best bet. Give them a call.
silencery is offline
Old 08-31-2013 | 03:24 PM
  #19
Depends on the battery cells - voltage (2S, 4S, etc). I don't see any mention of parallel operation in the Muchmore info so I would be leary of trying that to get 44 amps.
Using one 22A at maximum voltage it should be able to achieve around 15 amps each on a pair of 2S lipos. Half on 4S, etc. Perhaps a little less to not push the power supply to the max for a little headroom and better reliability.
Dave H is offline
Old 08-31-2013 | 04:44 PM
  #20
gotspeed24's Avatar
Thank you. And yea thats what im afraid of. Im hoping somone might see this thread and chime in with good news. Ill call progressive. Thank you again
Old 09-05-2013 | 02:53 PM
  #21
Syndrome posted this in another thread, it shows the size difference between the 4010 and the 308
Old 09-10-2013 | 05:54 PM
  #22
vabroom's Avatar
Any reviews on this charger?
vabroom is offline
Old 09-11-2013 | 10:50 AM
  #23
Check the battery/charger forum on rcgroups.
Old 09-11-2013 | 11:13 AM
  #24
Grasschopper's Avatar
Do I really have to weed out the 308 info from the 308/4010 thread or is there a thread that is off the first couple of pages dedicated to the 308 specifically?
Grasschopper is offline
Old 09-11-2013 | 11:22 AM
  #25
Originally Posted by Grasschopper
Do I really have to weed out the 308 info from the 308/4010 thread?
Yes, start reading. That's what I did.
Old 10-01-2013 | 06:16 PM
  #26
http://www.progressiverc.com/the-sur...00w-combo.html
Decided to take the plunge from a Radioshack PS and my old Duratrax ICE. Here's to hoping I like it.
jamesbernatchez is offline
Old 10-01-2013 | 10:43 PM
  #27
Racing4Evo's Avatar
Nice!
I have a similar setup but my PS is an Alinco 32A used for ham radios.
That description is misleading because it rates the PS at only 36A but it says you can charge 2x 2s packs both at 30A simultaneously which should be a 60A load on the PS which imeans there's 24A of phantom juice?
Racing4Evo is offline
Old 10-02-2013 | 01:39 AM
  #28
Racing4Evo's Avatar
Old 10-02-2013 | 01:41 AM
  #29
Racing4Evo's Avatar
....made my own charging lead. I only charge 2s packs so I ditched the balance board.
Old 10-02-2013 | 04:33 AM
  #30
Originally Posted by Racing4Evo
Nice!
The voltages are different, modern switch mode based chargers can change voltage fairly efficiently. Thus reduced current requirements with higher voltage supplies, within a charger’s input voltage limitation. The power supply is 17 volts, 2S is only 8.4V. In terms of power it’s enough (not much extra for headroom though).
Switch mode also allows the charger to handle batteries at a higher voltage than the supply, then more current would be required instead of less.
Older linear mode chargers did have that limitation, they only reduced voltage, required the same supply amps as the charge rate. Would get very hot with high supply voltages, couldn't charge higher voltage packs, etc.
Nice setup. Almost bought one of those Alincos once, looks like a sweet supply.
Dave H is offline
