question about sanwa super vortex zero
#121
This is a purely rhetorical question, but the SSL functionality only exists when the ESC is plugged into the SSL receiver port. Couldn't ROAR just mandate that the ESC only be plugged into the standard channel 2 port instead of requiring a lockout? That would be simple to check at inspection...
#122
Not saying you guys aren't right but there are a few ESC's with this instant reverse option on sensored motors but most as you say have brake first, then reverse. Hobbywing and Core RC are two that support instant reverse and are in common use in 1/12th scale classes here in the UK.
#124
#125
Just setting up my Super Vortex Zero and Exzes Z and have a question after reading through the posts. Does the race mode need to be activated in order for the speedo setting via the code function to work or will it still work with the race mode inhibited ?
The UK/English version of the Super Vortex manual, Rx-472 instuctions and the SSL instructions dont mention this at all they just mention turning the Aux 1 and 2 to Code via the system menu.
I see the Japanese instructions posted previously mention race mode on pages 6/7 but not sure if they are saying this is optional or its been updated since
Any one tried ??
Any one tried ??
#130
I just picked up the vortex zero I was able to calibrate it with my transmitter but I'm having a hard time selecting and changing the program mode. The instructions were pretty late am I supposed to leave the transmitter on or off when changing program modes? Basically I'm trying to select Advance timing mode
#132
#133
#134
#135
Please chime in your experience on your ESC's temperature. What's your highest reading?
I just want to make sure that on radio, TEMP 1 = Motor Temp and and TEMP 2 = ESC TEMP. But on the Thermal Protection reading, first reading of 120º C (248º F) is ESC and second is motor.
