Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 06-22-2013 | 08:03 PM
  #541
Originally Posted by billsharp34
is there a point in which if you go to far down on your CL will it cause more heat in the motor
+1 on that question
RC Geezer is offline
Old 06-23-2013 | 04:56 PM
  #542
bigbadbasher's Avatar
Picked up two at my lhs, installed one, it's randomly cutting out when landing jumps..
bigbadbasher is offline
Old 06-23-2013 | 05:03 PM
  #543
Originally Posted by Pulse_
CL helps for both temps and unwanted wheel spin, from my experience it's much more efficient than the punch control from castle who gives a strange "loose" feel to it. When adjusting the CL I didn't experience that lack of power in the power band. The response remains the same and you feel connected to the car whatever value you use. With castle I always ended with having no punch control because there was something lacking in the motor response, especially in low rpms
Noticing the same thing with my Castle in my 8ight 2.0, i bought two GEN2's and a couple t8's though. going all Tekin, i am already running two other Gen 1 RX8's with two t8's.. I figured i would try Castle but man, it's just not a Tekin, i noticed it big time today on a high bite indoor track.
Old 06-23-2013 | 05:31 PM
  #544
on/off switch screwing up
Mullet1 is offline
Old 06-23-2013 | 06:15 PM
  #545
A lot of us are using this gel mounting tape. The sudden shock can make it stop working for a few seconds. This is a common problem on the Gen 1, too. Since we began using this gel tape, it has never happened again.
Kyosho Zeal Vibration Absorption Gyro/Reciever Mounting Gel
http://www.amainhobbies.com/product_...Fc9DMgodrWsA2g
BSCFlash is offline
  #546
well i got two gen2 and the one works awesome but the other went up in a ball of flames soon as i hit the gas the first time im really hopping tekin will replace it for me. that was 200 bucks gone in about 5 secs. i have two of the gen1 and never had a problem once with them in two years.
billsharp34 is offline
Old 06-23-2013 | 06:23 PM
  #547
Ive never had that problem with my other two Tekins but ive seen that gel before, i may try it..
Old 06-23-2013 | 06:27 PM
  #548
Waflet's Avatar
Hideeho
Make sure you don't have any wires routed over the buttons. On a hard landing they can press the button & send it to program mode for a few seconds, just long enough for a marshal to get there, pick it up, & fiddle with it for another 30 seconds costing you a lap (ask me how I know).
Waflet is offline
Old 06-24-2013 | 12:41 AM
  #549
UK.hardcore's Avatar
220 Amps according to FET manufacturer spec sheet.
Got my wondering, you guys at the factory must have data about how much it can really handle over certain time?
UK.hardcore is offline
Old 06-24-2013 | 08:39 AM
  #550
Randy_Pike's Avatar
Team Tekin
Originally Posted by RC Geezer
+1 on that question
No
Randy_Pike is offline
Old 06-24-2013 | 08:40 AM
  #551
Randy_Pike's Avatar
Team Tekin
Please list the following:
Battery? Connectors used? Radio Receiver? Servo? Motor? Setup?
Old 06-24-2013 | 09:09 AM
  #552
Is there a chart for each LED value for CL without Hotwire?
BiggieFries is offline
Old 06-24-2013 | 09:15 AM
  #553
Randy_Pike's Avatar
Team Tekin
http://www.teamtekin.com/hotwire_RX8.html
Old 06-24-2013 | 09:50 AM
  #554
Originally Posted by Randy_Pike
Sorry if I missed something but that link only shows how to adjust CL using hotwire. I'm wondering what the values of the 13 different LED settings are when just using the buttons on the RX8. Or are there only 13 settings total and if you go into Hotwire it will tell you what all the values are? Sorry for the dumb questions just trying to learn.
Old 06-24-2013 | 09:52 AM
  #555
Protek 100C 4S 6700mah / Deans / Futaba / Savox (BEC set at 6.0) / T8 2050 / Running your setup from the Tekin page pretty much with a little less drag brake.
It's not wires bumping anything, the installation is very clean.
Only thing i can think of is the BEC board or it's thermo-ing and kicking back on, the buggy (losi 2.0) it's in, is not actually mine but i race with the guy and we both bought one, he put his in, ive yet to put mine in yet. The bad thing is, he is not a very good mechanic yet so i will try and run his buggy Wed and see what it's actually doing.
I am going to install mine tonight..
