Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 09-18-2015 | 07:51 PM
  #3076
rcgod's Avatar
Originally Posted by eortizr
Just got an RX8 g2 installed today. But after a few minutes of testing now it won't turn off. The on/off switch stopped working. Everything else works fine. It just will not turn off. Any ideas?
Cut the switch off and solder the wires together. The switch will fail eventually so might as well save yourself a DNF.
rcgod is offline
Old 09-18-2015 | 07:58 PM
  #3077
eortizr is offline
Old 09-20-2015 | 11:08 PM
  #3078
Volition's Avatar
Would it be safe to assume that if data logging is working. The sensor cable is all good.
Just thinking of a way to test that the sensors and cable is working as it should.
Volition is offline
Old 09-21-2015 | 06:06 AM
  #3079
hello folks,,,
I did not find a rsx tread..
so here I go..
I just finished building a dex410 with a tekin rsx and a speed passion v3 4,5t motor..
I blow my 16V tekin capasitor the whole time these days,,
Can I go from the 16V to the 25V capasitor???
BERG-V3 is offline
Old 09-21-2015 | 06:07 AM
  #3080
any ideas why the capasitor blow so fast??
on my fxr esc`s I use in crawling I have never blow`n a capasitor
BERG-V3 is offline
Old 09-21-2015 | 08:42 AM
  #3081
Randy_Pike's Avatar
Team Tekin
All Tekin brushless esc's have a built in sensor checker:
https://www.youtube.com/watch?v=ZRweNyXmD1I
Randy_Pike is offline
Old 09-21-2015 | 08:52 AM
  #3082
Randy_Pike's Avatar
Team Tekin
Originally Posted by BERG-V3
hello folks,,,
so here I go..
You can but I'd suggest finding out why the cap is blowing in the first place. This is often the sign of weak batteries, or a shorted motor.
Old 09-21-2015 | 09:29 AM
  #3083
Like I said I use a SP V3 4,5T motor and a Tekin RSX..
I have a 87/24 gearing and the motor is overheating after about 10min driving,
"thermal protection", but the RSX has never been warm at all...
I use a new Nano Tech 5,1 saddle pack for battery
I will try to go down on the pinion,because the 410 is flying with a 24T pinion,
I belive there will not be a BIG loss in speed from a 24T pinion to a 20 or 21
BERG-V3 is offline
Old 09-21-2015 | 09:50 AM
  #3084
Randy_Pike's Avatar
Team Tekin
You are WAY over geared for a 4.5T motor. You should be in the 18-19 range tops. Also if those batteries aren't sustaining voltage under the load of that 4.5T it will also cause issues.
Old 09-21-2015 | 12:21 PM
  #3085
I'm very disappointed with this Tekin, I though that it will be a product of better quality, I bought the RX8gen2/4030 1900KV motor combo, and after just one day of practice the ESC is now giving the 'Wrong Motor' error. I just sent it to Tekin for warranty, now the waiting game... I bet it will take at least 2 weeks to get it back.
eortizr is offline
Old 09-21-2015 | 04:16 PM
  #3086
Randy_Pike's Avatar
Team Tekin
Sorry to hear you had an issue. We're generally quicker than our 7 to 10 business days we quote you.
Once we receive them in, they don't stay very long.
Old 09-22-2015 | 04:56 PM
  #3087
Has anyone had a issue with intermittent throttle on their RX8 Gen 2,I've tried 2 different 1900 T8's with the same results.Was running on a very slick track. Would just loose throttle but had steering and it would come back after a few seconds. Checked all wiring
Reedy 4600 55c 4s pack
Futaba 4PK-S
Throttle epa 85
Brake epa 45
Throttle speed 100
Throttle expo - 25
RX8 Gen 2
Current limiter 55
Servo voltage 7.4
Throttle min. 0
Neutral width 10
Timing 10
Geared 44/18 in Tekno EB48.3
X God is offline
Old 09-22-2015 | 05:26 PM
  #3088
Futaba 4PK-S
Throttle epa 85
Brake epa 45
Throttle speed 100
Throttle expo - 25
RX8 Gen 2
Current limiter 55
Servo voltage 7.4
Throttle min. 0
Neutral width 10
Timing 10
Low voltage cut-off?
Andy Koback is offline
Old 09-22-2015 | 05:33 PM
  #3089
R/C Tech Elite Member
Futaba 4PK-S
Throttle epa 85
Brake epa 45
Throttle speed 100
Throttle expo - 25
RX8 Gen 2
Current limiter 55
Servo voltage 7.4
Throttle min. 0
Neutral width 10
Timing 10
check c post on esc , make sure not getting loose on circuit board..
bpalmer is offline
Old 09-22-2015 | 07:51 PM
  #3090
vandalzzz's Avatar
Radny, i'm just curious: is it possible to add motor thermal cutoff into ESC firmware? Anyway ESC can see motor' temps (logging it), why not add adjustable therm. cutoff with 'no limit' value to esc?
vandalzzz is offline
