Official Tekin RX8 GEN2 ESC Thread >
Like Tree20Likes
Old 07-09-2015 | 06:40 AM
  #2941
Hoese37's Avatar
Originally Posted by blackshark3
Just wonder if anyone had this experience...
I put on a brand new RX8 Gen2 onto my new Mugen MBX7R Eco. On the bench everything works fine, and I could even tuned the ESC with hotwire and ran it around my home a couple of circles. Today when I bring it to the track, after connecting the batteries and tested servo right before I put on the body the ESC smoked and fire burst out from the fan! I immediately disconnect the batteries and was able to tear the esc off the chassis to put off the small fire. The ESC was ruined and it ruined my my day...
I heard and saw quite a few RX8 caught fire while the car was running, but blowing up before putting it on the track is really discouraging. Frankly my confidence on the RX8 is lost...
This is a twofold situation. Part one: Every once in a while there will be a dud from the factory. Happens with any manufactured goods of brand, price, model and product. Two: If the failure rate was 1 in 100 for tekin, and 1 in 50 for a different brand, you will see more Tekins fail if there are 1000 of those compared to 100 of the other brand. Don't get discouraged at this point, you purchased the highest quality ESC on the market.
Hoese37 is offline
Old 07-09-2015 | 07:07 AM
  #2942
Default Hotwire App Motor Temp Calc
Has the motor temp calculation in the data log on the hotwire mobile app been corrected yet?
qstorm777 is offline
Old 07-09-2015 | 04:24 PM
  #2943
Default Data Logger
Also, I still can't get data logger changes to take. I change the settings in data logger, close data logger and download settings from Hotwire. Am I supposed to leave data logger open or download the changes another way?
Old 07-11-2015 | 01:53 PM
  #2944
Originally Posted by Calde315
Had an issue last weekend in my Tekno and this thread seems to be more active. I have a Gen2 RX8 with a Pro4HD and I ran a full 7200mAh battery through it outdoors. After I was done, I bought it back and plugged in a new battery and nothing turned on. Thought the battery was dead maybe, but verified it wasn't and tried a different one to boot. Same thing. Packed it up and did some diagnosing at home and realized once the fan was unplugged things worked as they should. Or it seems to I should say, as I didn't have it in the car or connected to the receiver.
Are fans notorious for going out and shorting these ESCs? It seems to me a new fan would do the trick, but wanted to make sure I asked those that know 10fold more than I do before blindly ordering fan(s)
Alright, I've taken off the fan and realized that one of the wires was rubbing on the ESC cooling fins below and has worn through the silicon sheath, providing a short for the ESC.
I have found a non-Tekin replacement, as I haven't read really great things about the fans and I can get two for the price of one Tekin fan. I just need to find out what the connector is that is used. Any help there? I can measure the pin spacing and get somewhere close, but figured maybe someone has already done this. I have the right crimping tools and would rather make a couple to have on hand in case.
Calde315 is offline
Old 07-15-2015 | 04:46 AM
  #2945
jag5508's Avatar
Is their a general Tekin thread on here? I have to send a couple things back not sure how their return for repair or replacement policy is. I have to send back an RSX combo and a hot wire thanks any help would be appreciated.
jag5508 is offline
Old 07-15-2015 | 05:23 AM
  #2946
On Tekins website they explain the procedure for sending back repairs.
freebird is offline
Old 07-15-2015 | 09:12 AM
  #2947
Randy_Pike's Avatar
Team Tekin
Please contact service@ or support@ to get the ball rolling.
Randy_Pike is offline
Old 07-15-2015 | 09:26 AM
  #2948
Randy_Pike's Avatar
Team Tekin
NO reason to lose confidence. Anything can fail at any given time, it's Murphy's law at times as they say.
Please contact service@ or support@ and give them as much info as you can to help them determine what step is next. They like to get car info, gearing info, battery info, servo and radio system info, etc.
Old 07-15-2015 | 09:41 AM
  #2949
jag5508's Avatar
I'll do that either tonight or tomorrow. I had all 3 screws fall out of my motor after 2 1/2 battery packs. I thought it was my diff grinding come to find out the motor just fell apart. Then my RSX the data and port don't work.
jag5508 is offline
Old 07-21-2015 | 09:08 AM
  #2950
Default wires
Hi, can some tell if is it possible to use the default wires which comes with my new gen 2 12awg ?They are so tight
Thanks for answer.
shadower is offline
Old 07-21-2015 | 09:12 AM
  #2951
Cain's Avatar
Tech Legend
if I am understanding you correctly, you are concerned about how thick they are?
In standard 1/8 Usage I wasn't concerned for my 1/8 buggy and truggy and have no issues to report.
Cain is offline
Old 07-21-2015 | 09:31 AM
  #2952
Randy_Pike's Avatar
Team Tekin
How did you determine this?
Old 07-21-2015 | 09:32 AM
  #2953
Randy_Pike's Avatar
Team Tekin
Thanks for answer.
Check out out "How to wire and Rx8 Video"
Old 07-21-2015 | 09:34 AM
  #2954
yzracer758's Avatar
Team Tekin
Thanks for answer.
The 12 awg wires that are included with the RX8 Gen 2 esc are perfect for any 1/8 or 4x4 SC Setup.
yzracer758 is offline
Old 07-21-2015 | 09:50 AM
  #2955
interested, i cant believe it handle 4s 6000 50c ...220amps as the spec of tekin say
shadower is offline
