Official Tekin RX8 GEN2 ESC Thread
#2341
A lot of the guys here in our area run the RX8 Gen 1 and Gen 2 in their 4x4 short course trucks. All of the ones that run the Gen 2 are having problems with battery damage and thermal ing our on 2 and 3 cell, I have a Gen one with Pro4000 I can run 2 or 3 cell on mine 16 pinion in a Losi scte all day on all the tracks. (we have 4 ovals in the area) The guys with the Gen 2's set up exactly like mine, have problems, puffing expensive hi C rated batteries and thermal ing out. We have talked to a few folks at tekin and they stand by the Gen 2 (obviously) I just sent one to tekin today that would puff batteries and thermal out, it finally died light 1,2 6,7 wrong motor type selected, which is usally the kiss of death on a tekin esc. Surely there are some setting you can set the Gen2 too to make it run like the Gen1. I like the features of the Gen 2 but I'll take the Gen 1 all day and ALL the oval racers around here will too. We all run tekin pro4 motors of some kind (and love them) wish we could get the Gen2 to run our stuff.....
As it stands if my Gen1 dies, I am going to something else..... Die hard Tekin guy here I have tons of 1/10 scale stuff RSPRO is the best esc ever made bar none...... Just sayin....
#2344
We are listening, as always… This is the first we have heard of a gen1 to gen2 difference and there is no good engineering reason that I can immediately think of to explain it. There may be something hiding here that we do not understand yet and we are happy to try and figure it out.
Thus far all we know is that a group of SC4x4 oval drivers that push everything to the limit and drive full wood the entire race have puffed a few batteries, and they happen to be using Rx8gen2 units, and 1 of them actually did fail.
SC4x4 is the heaviest load in RC period! They are almost 1/8 scale weight cars on half the battery. Even offroad racers puff batteries now and then in these cars because they use almost all of the battery capacity each run and pull high currents. Now race them on an oval hammer down and you have the worst of the worst loads for a battery in RC.
Considering some of the drivers in your group are running 4000kv motors on 3s, and others are trying to keep up with 2s systems it is at least a possibility that you are just pushing too hard with setups and this is not a RX8gen2 design problem.
All of the other systems that ‘have’ puffed batteries appear to work normal and are not damaged indicating again that there is at least a decent possibility that the problem is not in the Rx8gen2.
Technically any battery rated 50C or higher should handle these loads without any issues. The reality of C rating accuracy on batteries is perhaps another conversation…
To start with we need some settings in the unit, specifically the timing and gearing. Also need to know how much the batteries are taking when you recharge them. Motor temps and esc temp would be good. An actual data log of a good run and then a log of a run that puffs a battery would be awesome. Again when we are pushing the batteries to the limit already in a SC4x4 it does not take much to push them over the edge. In extreme applications user setup is critical…
#2345
Thanks, I feel much better. I will be racing on an indoor track that is not wide open at all. I think the prez hit it on the nail, go to 3s to cool things off. You need a lot of fresh air moving, and fans on those. I have a friend who did burn one up and he also feels the Gen1 was better. He is running a Tekno, and those things are heavy and put quite a strain on the power system. I wonder if the high c rating is actually hurting it.
#2346
A Pro4 4000kv on 3s is certainly not a recommended setup if Prez is accurate, and I'm sure he is.
Oval is one of the heaviest non stop forms of racing, aside from boats.
So how big is the run line? Where are you gearing them? What tires? SC bodies or something else?
The Rx8 Gen1 vs Gen2 is a push. If you're thermalling either post your settings, gearing, track info, and a picture of what we're working with and we'll be sure to help you sort it out.
As with any problem the more info you provide us, the quick and better of a solution we can provide you.
#2347
As we discussed on the phone we need more information. I thought we were going to work together to gather some real engineering facts and solve this isolated problem. Have to say I am disappointed to see this post immediately after our conversation considering the time I took to discuss it with you and the plan we had to actually measure some things to figure it out. Happy to do this publicly so everyone can learn from it, or you can answer my questions privately by email so we can make some sense of this.
#2348
Thank you for your input Mr Campbell, I must first say we have never spoke on the phone to my knowledge, I havent called tekin in a good while. At the track I run, we have a 220 ft run line with 7 second laps, we might be off the throttle 1.5 s seconds at each end of the track. most run Losi or Tekno 40 spur and 15 - 17 pinion gears, off track after temps= most are running 150 max on the motor, 120 ish on the esc and 100 - 105 mAX battery temps, Speed control setting on most of our esc s are set to factory basic settings, we dont boost 1/8 like we do the 1/10 for sure. Question, would running 3 cell with much less gearing be easier on the ESC overall ? And maybe running a lower Kv motor on 3 cell ? Thanks Take no offence at my posts, just being honest that the Gen2 doesnt offer us the same as the Gen1 on the exact same setting
#2349
This is the Ve8 buggy right? I ran that car and know what gearing should be in it, trust me. You're going too far with your gearing "changes" in general.
The Ve8 is a car with a 50T Spur and 4.3 diff ratio. So with my suggested gearing of a 23T pinion, 50T spur and 4.3 diff ratio your'e at 9.3 FDR. A TLR in comparison with a 45T Spur, 16T pinion and 3.3 ratio is 9.2 FDR. Nearly identical.
If your deans melted it was a loose or bad connection and may be the shut down source in the first place. Deans are good connectors but if they get loose or the plates get burnt...they're done and should be replaced. What sucks is they're hard to see inside, especially the battery/female side.
#2350
I highly recommend the RX8 Gen 2 for 4x4 SCT.
#2351
#2352
lower Kv on 3S is the better set up. Every time I see a 4x4SC blow something up its related to drawing to many amps. higher voltage means less amps. In fact, IMHO, 4x4 SC should be something in the 3000 to 3200kv range on 3S bettery, not 4000Kv to 4800kv on 2S. I hate the class so I don't have to worry about it.
#2354
@IMRob "185 for motor temp and 153 for the esc with out the fan on" is an acceptable motor temp on the Rx8 Gen2 and T8.
9 times out of 10 when I hear of someone having issues it's related to setup, gearing, etc. 4wd SC is the highest amp draw class we have in rc racing right now. As previously stated they're the heaviest cars, with the fastest lowest turn motors, and least amount of battery voltage at 2s.
4wd SC oval guys:
The 4wd Sc chassis was never designed for oval racing. So you're taking a car and using it in a manner it wasn't intended. Then you're using a 4000kv motor which is meant for 2s not 3s. While this "may" work at times you're dancing with an edge and you guys have found it.
I'd like to see some video of those trucks hustling around the track. Anyone have it?
4wd SC oval guys:
#2355
4wd SC oval guys:
4wd SC oval guys:
20Likes
