Who charging 20+ amps or more now?? >
Old 09-06-2013, 05:28 AM
  #481
Jerz616's Avatar
Trader Rating: 49 (100%+)
Can you use a smaller power supply. Like a 25A 250w that I used on my hitech x4. Would it allow me to use most of the features until a larger PS was purchased. It shows you can use a 60A, but do you have to have that large of a PS.
Jerz616 is offline
Old 09-06-2013, 06:04 AM
  #482
Originally Posted by Lycan
Just noticed there are 2 1200watt PSU's from efuel (skyrc), 15-24v 60amp or 15-30v 50amp. Looks like the 30v one was just added.
60a one, it should normally give a little extra!!
Jampot is offline
Old 09-06-2013, 08:37 AM
  #483
Trader Rating: 64 (100%+)
Everyone needs to figure their actual wattage requirements before they go spending a shload too much money on more power supply then they will ever need.
MC112b is offline
Old 09-06-2013, 09:03 AM
  #484
Jerz616's Avatar
That's kinda what I thought. I usually only charge a 2s at a 2C rate. So most of mine are charged at 14A. And I believe that equates to 118. Even at 20A it would only be 170 max. So at that rate my 25a 250W PS would be fine I would think.
Jerz616 is offline
Old 09-06-2013, 09:51 AM
  #485
JiuHaWong is offline
Old 09-06-2013, 10:01 AM
  #486
Regional Moderator
CarbonJoe's Avatar
http://www.ebay.com/itm/HP-Proliant-...item2c721840ef
$5.94 + $7.95 shipping = 12v, 74A on a standard 110v outlet.
As stated before, the fan is a little loud, but the PS is a tank.
CarbonJoe is offline
Old 09-06-2013, 10:19 AM
  #487
Exactly, like I don't have enough crap to drag to the track. I have plenty of space for a "tank" of a power supply I'm only going to use 15 percent its total potential.
MC112b is offline
Old 09-06-2013, 11:42 AM
  #488
Regional Moderator
CarbonJoe's Avatar
Tough to find a PS (especially at that capacity) that is only $13.89 shipped. If you run a foam car (WGT, 1/12 scale, etc) and have a tire truer, this one can power that as well. Or tire warmers, etc. Think outside the box.
Old 09-06-2013, 11:55 AM
  #489
If u would like to work out the watts required.
My lipo's are 6000 mah
The charger charges at 70a
I charge to 8.44volts
The power supply I'm looking at has 15-24v supply adjustable.
It was mainly the max discharge amperage I can discharge at using power supply not a 12v battery.
And will that power supply cater for a 70a charge rate?
Obviously I will have tire warmers running
And possible a few other small items wheel balancer etc
Jampot is offline
Old 09-06-2013, 12:35 PM
  #490
I totally get the "bang for the buck" scenario. I live by the server supply mod mentality. A name brand supply of any real watts gets very expensive quickly. I personally put some value in form. Loud, heavy, and large aren't things I look for in a carry rig. That's my opinion, but not exactly what I was trying to imply.
I'm encouraging people to analyze what they currently have. In a lot of cases there's no need to spend the money on something they technically might already have.
I blew a guys mind when I explained that his old "15 amp" supply actually had the wattage to charge his 1s batteries at 20 amps. This is the type of guy I'm trying to help.
Parallel charging a few 4s batteries at 40A, yes, we're talking serious hardware upgrades.
MC112b is offline
Old 09-06-2013, 12:41 PM
  #491
Trader Rating: 88 (100%+)
I know the feeling. Right now I'm lugging a Pyramid 30 amp PS around, and I just about need to tow a trailer behind my pickup truck just for that when I go to the track.
MUDVAYNE is offline
Old 09-13-2013, 08:35 AM
  #492
John Tag's Avatar
Trader Rating: 42 (100%+)
What's the highest anybody's been able to discharge with there 306Bs on a 2S.
John Tag is offline
Old 09-14-2013, 03:29 AM
  #493
daleburr's Avatar
I think 10a if you're connected to a power supply. 30a if connected to a 12v leisure battery using regenerative discharge
daleburr is offline
Old 09-14-2013, 10:08 AM
  #494
http://www.rctech.net/forum/12538939-post33.html
Found this product interesting.
Does anyone know what the Turbo 35 GFX discharges at? And will it discharge to a safe lipo storage voltage?
Old 09-14-2013, 10:34 AM
  #495
You can set the GFX to end at a specific voltage. It will discharge at 35 amps.
I still use one consistently for the nostalgic race feel. If I'm running 1s it's all I'll use. My PL8 does a nicer job probably, but doesn't feel or look the same.
That, and the regenerative discharge thing is a crock, total PITA if you ask me.
I'd buy an updated GFX type CE charger tomorrow if it had the real 40a faculties and built in balancing.
MC112b is offline
