Like Tree8Likes
Lap Timing Decoder
Old 09-30-2013 | 06:38 AM
  #301
howardcano's Avatar
Originally Posted by maeg
I think it possible to do you amplifier to test - I don't so skilled in electronics, but there is one guy who can help me.
But then first question - may be it need to do some changes so you loop amplifier can work on our wide outdoor track - 6.5 meters?
It's worth a try. You will need to decrease the value of C1 in the loop amplifier. The correct value will vary with the size of the loop, and I can't say what that would be. As the loop size increases, it reaches a point where it simply can't be tuned high enough (5MHz). Also, the signal levels induced in the loop from the transponders will be lower, making operation sporadic.
Please let us know of the results of your experiments, if you decide to try.
howardcano is offline
Old 09-30-2013 | 07:45 AM
  #302
@Meag: Have you experiened the misses at evening-time, after sunset? I experience lots of interference at evening. During the daytime there is better decoding. I think the reason is the loop-amplifier is a broadband design, were only the resonance of the loop (L + C) is responsable for some filtering of shortwave radio_stations that come in after sunset. I have now noticed this for several times, not moving the loop and checking during daytime and nighttime. Tell me what you experience is.
Note: my hobbyroom (as well as the loop during tests) is at the second floor of our house. Possibly when the loop is at groundlevel, the above is less true...
PA3EXV is offline
Old 09-30-2013 | 07:57 AM
  #303
We use this decoder at 4 tracks - 2 on-road and 2 off-road, and loop underground at all (2-3 sm under surface). We try race at 9 and 10 pm and all work very good.
The only problem we have - is that i said prevously - on large track where loop length 6.5-7m we have many misses. And there is no difference between ambrc, amb rc4 hybrid, cano or paylaneg's chips - on small loop all works perfect, on large - we have problems.
maeg is offline
Old 09-30-2013 | 07:58 AM
  #304
yes, we will try!
I'll write as soon as i get results.
maeg is offline
Old 10-01-2013 | 05:26 AM
  #305
howardcano's Avatar
This might be a problem if you are right next to a radio transmitter operating near 5MHz, but otherwise those signals will be several orders of magnitude smaller than the transponder's.
However, humidity normally increases after sunset, and if you are using a buried loop (which I DON'T recommend) then the loop tuning and sensitivity can be severely degraded.
Old 10-02-2013 | 05:57 AM
  #306
Howard: Would you have any interest in going commercial with this? You have a design that clearly works and can be built for a fraction of the cost of a mylaps system. You and the other guys who have been working on this have done an incredible job, but constructing this system is still a bit beyond the capability of most RC hobbyists. If you were able to produce complete systems, I think you would sell quite well. As you've mentioned, the page views show there is clearly interest in an alternative transponder system. I know that the startup cost of doing a proper production run is nothing to sneeze at, but maybe a kickstarter project could amass enough funds to cover that?
Thank you for your efforts so far.
Candre23 is offline
Old 10-02-2013 | 06:51 AM
  #307
howardcano's Avatar
The startup cost would likely be over ten thousand dollars, which personally I do not wish to spend. I'm also not much of a businessman! The kickstart concept is interesting, and might work well, although I don't really want to be the executor.
My preference would be to partner with someone to run the business, while I remain a technical consultant. I could sell rights to the entire design (all of which I have already provided free, except for software), or simply sell programmed microprocessors to someone who wanted to produce the decoder (which is essentially a way to pay and collect royalties without the bookkeeping). Buying/selling microprocessors has the advantage that there is no up-front cost for the design for the manufacturer. Buying/selling the design has the advantage that the software doesn't disappear if I get squashed by a bus.
One of the purposes of the thread was to find a partner or company (or several!) who would produce the design. I still hope that will happen.
Old 10-02-2013 | 07:41 AM
  #308
I hope it will too. I wish I was that guy, but I'm no businessman either. Good luck!
Candre23 is offline
Old 10-02-2013 | 10:17 AM
  #309
I would think that one of the key factors in offering an alternative decoder is being able to have compatibility with the AMB/Mylaps decoders as they are so prevelent in the Rc world now. I believe Howard's design is currently compatible with all but the true Rc4 transponders, and even was reported working with the new MRT.
I would love to see this project move forward to the commercial step, but like many others, do not know the first thing about business concepts.
I appreciate all the hard work Howard and others have done to lift this project to what it is today, and sometime in the future would love to see an alternative to Mylaps.
Compitition is good right!!!
brew99 is offline
Old 10-05-2013 | 08:07 AM
  #310
I never provided an update after we finished our summer camp, where I tested a preliminary transponder/decoder. My previous post has pictures of the decoder which used a Lattice CPLD, PIC 18F and a FT232RL cable.
We got it to work nicely with RC cars (under a wooden ramp) and with adult go-karts on a tarmac track. For the kart track we used some vinyl flooring (as found in bathrooms) as we couldn't bury the cables. The loops for both were made from wire stripped out of an old CAT5 cable.
Since then I have done a bit more work on the CPLD side and implemented the CRC checking in hardware. I have a few other ideas to test before next year and I want to get the whole decoder onto a PCB.
Attached is a picture of our high tech track control hut. It was sunny all week but decided to pour on race day. You can just about see the black coax trailing off and the brown vinyl flooring in the background.
edeca is offline
Old 10-06-2013 | 02:58 AM
  #311
howardcano's Avatar
This is very good news!
How much interference are you encountering from the kart ignition systems?
And who had FTD?
Old 10-06-2013 | 06:33 AM
  #312
The transponders were powered from a 9v PP3 battery and not from the engines. We run both 4 stroke and 2 stroke karts and I did not notice any problems from the engines interfering with the loop.
I think we had one case where a lap was missed but aside from this things were good. My code implemented an 8 bit CRC so incorrect detections should be improbable.
And who had FTD?
We only measure using the IOF! For RC cars we divide the young people into two groups and do team endurance racing, one lap each with total laps as the
measure. We try to tell them that accuracy is much more important than speed, but they don't always listen
In go-karting it was a close run thing between two of the leaders, a few hundredths of a second across a ~26 second lap. I'm working on getting the CPLD/FPGA to manage the race clock so that I can timestamp events coming out of the SPI and more accurately determine these small 1/100th second times.
edeca is offline
Old 10-06-2013 | 07:54 PM
  #313
mick33b4's Avatar
All on one board sounds like a good direction.
As long as the soldering isn't too intense, have you guys considered offering this as a kit with a board, programmed ICs, and a parts list?
Might be a good way to work through a beta phase and work out the bugs before investing toward production.
mick33b4 is offline
Old 10-07-2013 | 02:57 AM
  #314
All-in-one system is defenitely the way I prefer. By using the CPLD and SMT components, this is the way I work it out for me. It even already exists and is commercial available (not from me to be clear):
PA3EXV is offline
Old 10-07-2013 | 03:58 AM
  #315
howardcano's Avatar
Which system is this? It looks nice!
