SMC LIPO BATTERY THREAD
#2866
IDK I could be
I also just order the 4s 3500mah for my pro8 buggy
#2867
probably shouldn't be making this comparison but last night race at my local track did 3 rounds of qualifying on nano-tech's and the main on SMC Race Formula's, fair bit of a difference, had to change my throttle control a fair bit to stop over-jumping the double-double on our track. 10 minute main with no noticeable voltage drop too. So far loving the SMC's.
#2868
This was the second time using my 4600mah 70c shorty in my 17.5 stock blinky SC10.2 last night, and the battery cracked..I recently sent a battery in a couple weeks ago because the first time I used it, it got super hot after a qualifier and melted my battery strap into the battery. (LVC being at 3.4) Now I don't know what to do...
Second battery that something bad happened now..
Do I electrical tape it, or send it in hoping to get another?
#2873
If so you are running a total lvc of 3.4 not 3.4 per cell.
How long was the run that melted the strap?
#2875
The case is not puffed at all, it cracked by the inputs. And yes, I was referring to 3.4v/cell for LVC. It melted after a 5 minute qualifier. I sent it in because he thought there was a problem internally. He sent me this new one, that is now cracked after my second run with it..
#2876
Putting a shorty in a SC10 takes a LOT of filler. If you put in a shorty without foams it will move around no matter how tight you crank the strap down.
#2877
Wow...a crack?
I've only had a crack case one time and that was went a mod touring car decided to slam into my F1 car on the back straight. Like what 1967 said, make sure you have foams when running shorty in the SC10.
#2878
I have an alternative battery strap. I drilled holes on either side of the battery compartment, inches away from each other, threaded B4 axles in, and had a solid thin bar go across so that problem wouldn't happen.
#2880
If they have a tiny bit of room to wiggle around, they will absorb a LOT of forces. That is why foams are generally used to suspend the battery. You can't allow them to move and potentially bang into a solid part of the vehicle. That is too much for these batteries.
11Likes
