-   -   LRP IX8 (https://www.rctech.net/forum/radio-electronics/551319-lrp-ix8.html)
Sylvain 07-16-2012 04:11 AM
Originally Posted by dfsc10 (Post 10978208)
thinking about purchasing the ix8. I had a rx8. just a couple questions... are they reliable? are they setup to run right out of the box with no programing?
Yes they are good, I have one in my RC8.2e and I like it.
The ESC comes programmed from the factory but you must set it up to your configuration (number of cells, brake, punch control, cut off, etc etc). They are quite easy to program with the buttons and leds
RcRacer27mx 07-16-2012 11:24 AM
I like mine. Especially the no soldering directly to the speedo part. ;) Just follow the light sequence and push buttons at the right time. :)
dtr 07-16-2012 12:07 PM
Dust will jam the buttons, it had once stopped halfway through a main with a thermal error, but it was nowhere near as hot as it is after 10 minutes, internal temp check doesn't work on mine, otherwise it works so far. Programming is very limited (or simplified, if you like it that way), number of cells for lipo cutoff (2-6), brake on/off, reverse on/off, motor direction, power profile(1-5), drag brake level(off, 1-5).
rocko117 07-19-2012 11:26 AM
hey is anyone running the ix8 with the dynamic 8 1800kv motor? i'v herd of people running the 2200 with high temps but 2200 is a kind of high kv for raceing.
HeavyD99 08-11-2012 06:23 PM
Soldering to the board
Hi guys, sorry to hijack the thread, but I just picked up an SPX8 to use in my 1/10th 4WD and the servo wire, negative wire, is pretty frayed - I once tried to replace the same three wire/servo lead on an LRP QC brushed ESC years ago directly to the board, and it never worked again, sent it in to LRP USA - they said I fried the board, no warranty etc. So, all this to say, my SPX8 has a frayed wire, I'd like to replace the entire servo lead - can I do this myself, soldering to the board itself or would I be better to simply cut it at the frayed section, and redo the wires?
Any advice?
Thanks guys.
scooter1 08-15-2012 07:14 PM
Hey guys, just picked up an ix8 and I'm having a bit of trouble. The lrp website is of no help so I thought I'd try here. I have it in my rc8.2 with a tekin 1900, spektrum radio/receiver, and I usually tun thunder power battery. 2 issues are baffling me, the first is that when I turn the car on, with the transmitter already ON, the car blips full throttle for about 5 seconds. I've never experienced anything like it. After that it runs correctly. Except that when I try to adjust the travel down to 80 the car then wants to creep forward until I adjust the throttle trim to ~-10. The transmitter/receiver have been bound correctly and I've calibrated the esc with the radio correctly, as far as I can tell. The only other things I've done include setting the voltage cutoff for 4s and setting to be able to go in reverse. Any thoughts would be appreciated! Thanks guys!!
DaveG28 08-15-2012 07:41 PM
Originally Posted by ruicortez (Post 10521750)
Now I know what happened. The problem was not with the software, but with the button. The Mode button was not working. After a few days using the ESC the plastic button started to shrink and doesn't reach the point of contact inside the ESC. I disassembled the ESC's bottom cover and took the button off, and now it is working. I just have to use a small allen wrench to press the mode button inside the ESC, until I can get a new button.
Anyone else done this? Both mode and set buttons are no longer working on mine, and I'm in 2 minds about trying to fix it as it is set how I probably want it anyway....is it easy to take apart and reseal?
Thanks!
jhautz 08-15-2012 09:14 PM
Thanks!
My buttons stopped working after a couple really dusty race days. I opened the esc case and blew the dust out of the buttons with some canned air and then sprayed them out with some electronics/motor cleaner and they were fine again. On mine the little buttons on the board wouldn't push without cleaning them out. The little plastic buttons in the case had nothing to do with the problem.
pballer2777 09-12-2012 06:16 AM
fan?
i got a new ix8 and i installed the fan. when i power up the esc the fan doesnt turn on. should the fan come one right away or does the esc turn it on when it reaches a certain temp?
DaveG28 09-12-2012 07:25 AM
Hi there,
It should turn on for 3 seconds when you first switch on the esc, then it stops and only comes on at 130 degree's? I think it only turns on at startup if everything is connected up though (motor, sensor etc).
pballer2777 09-12-2012 08:09 AM
Originally Posted by DaveG28 (Post 11201988)
Hi there,
it doesn't come on at start up. not sure if it comes on after it warms up since i didn't run it with the fan yet. i just installed it last nite and bench tested it.
DaveG28 09-12-2012 08:53 AM
Ok, I think it will only come on at start up if you have it fully wired up to both receiver and also motor...the fan at start up is a "test" that everything is ok...I have vey rarely had mine reach the 130 to get the fan going once hot but I do think it should work at start up or there is an issue...not sur did anyone can chime in!?
powis 09-12-2012 11:10 AM
Any one have the experience on the ix8 that the reverse function sometime doesn't work??? I have already upgraded the firmware to latest one.
bobseagull 10-14-2012 02:49 AM
dynamic 8 2200 problem
have been having problems with the wire holders on motor coming off , today i had all yhree come off at once, any one had this prob and have a fix, not much room for soldering on these motors , wish they had normal solder tabs.
Tran901 11-14-2012 06:21 AM
i currently run a LRP ix8 paired with a LRP 2200 Dynamic 8. lately, i have been having problems with it cutting off. it started with jumps, then small jumps, not it just cuts on straights. sometimes only at 1/4 or 1/2 throttle. the switch has been cut off. and once it stops, you can unplug and plug the battery, and it works fine until it quits again.
car: Rc8e.2
ESc: Lrp Ix8
Motor: Dynamic 8 2200kv
Battery: Reedy 4s 60c 5500mah with EC5 connector
Servo: Savox 1283 with novak cap
radio: Ko Propo was Spektrum dx3r pro (cut off on both radios)
LVC is at 6v and overheat is on. it made 2 laps saturday in the mains on a 23 sec lap track typical is 26-28 sec lap...so that gives you an idea
any input would be great before is send this thing back to LRP for repair!!
thanks
daniel
