screw size for hitec servo >
Old 08-09-2011 | 07:07 AM
Default screw size for hitec servo
What size screw are the threads in a hitec hs-7950th servo?
thanks.
rc_speed is offline
Old 08-09-2011 | 07:10 AM
scwrod's Avatar
http://www.rctech.net/forum/ask-hite...-question.html
scwrod is offline
Torian4000's Avatar
2.6x8mm
Torian4000 is offline
Old 08-09-2011 | 07:13 AM
token's Avatar
http://www.amainhobbies.com/advanced....6x8mm&x=2&y=3
And they are NOT hard to find...... just sayin
token is offline
Old 08-09-2011 | 07:20 AM
Ruune's Avatar
They also happen to be the same size as a lot of engine backplate screws. I realized this when I was wrenching one day and didnt want to drive over to the LHS.
Ruune is offline
Old 08-09-2011 | 08:01 PM
houston's Avatar
houston is offline
Old 02-09-2016 | 09:39 PM
M2.5 x 8mm screws tend to work. Here is a link for 500 screws for AU$119. M2.6 screws are extremely rare, except on expensive hobby websites, and 0.1mm diameter makes hardly any difference. So why not order 500 of them, stainless steel 304 grade with a nice allen key socket? That's around 4 cents per screw. You need not ever pay more than 10 cents per screw, including delivery. So buy a few more for later.
Qty 500 Button Head Socket M2.5 (2.5mm) x 8mm Stainless Steel 304 Screw Bolt
I can't provide links here yet but search for the above phrase or similar on ebay.
Zxen is offline
Old 02-09-2016 | 10:33 PM
Roelof's Avatar
Tamiya has M2.6 screws
Roelof is offline
Old 02-10-2016 | 08:00 AM
First; you're 5 years late on this topic.
Second; if I try to use a 2.5mm screw on my Hitec servos, I can usually pull it back out with my hand. The proper M2.6 screw holds tightly in the same servos. $3 for 6 or 8 screws in the correct size is a lot more useful than 500 in the wrong size, especially when you only use 1-2 of them per car.
kawi650 is offline
Old 02-10-2016 | 08:26 AM
Billy T.'s Avatar
Originally Posted by kawi650
First; your 5 years late on this topic.
Second; if I try to use a 2.5mm screw on my Hitec servos, I can usually pull it back out with my hand. The proper M2.6 screw holds tightly in the same servos. $3 for 6 or 8 screws in the correct size is a lot more useful 500 in the wrong size, especially when you only use 1-2 of them per car.
TY
Billy T. is offline
