calling all FUTABA 3PK users.....
#601
Johnnyboy,
I know you recently switched from an M11. What do you think of the 3PK so far compared to the Airtronics?
#602
I am LOVING it! The M11 was a great radio and the menus were a little bit easier to use, but the 3PKS is so much lighter and balanced in the hand. I found the M11 a little too much front heavy. I don't know if I can tell too much of a difference in the FASST system over the Spektrum, but overall I am very happy with the Futaba package. With a little more track time, I am sure the menus will be easy to remember.
#603
I also switched from the M11 and never looked back. The only thing I preferred was the trigger (the gap in the 3PK's is a bit wide) but a little of fuel tubing fixed that. The FASST system is also awesome.
#605
I'll try the polyurethane paint and see what happens. I'd like to paint my sister's radio and my radio, so thanks for the reply. Sister's radio is a crappy HPI radio. I can't remember the model or manufacturer. I thinks it's futaba. IDK. But she'd be happy to have here RTR radio painted. I'll try it this weekend and see what happens.
#606
i just got my first 3pks today , it has the FASST system , hopefully i have good luck with it. i also bought the 27mhz module for it so i can run my mini-z's and a few other models i run on am , so far programming everything went smooth , both of my 1/10 electric have castle creation mambas and the set up was a breeze.
#607
i am having an issue with my 3PKS where sometimes the steering wheel doesnt turn smoothly and it feels like I have to give it some extra energy to get it to move. Not sure why this is happening. Is there any kind of tension adjustment that may have gotten out of whack?
#608
Take Care,
Cheers, Patrick
#611
Yes, that's exactly what happened to my 3pks, but I still did not glue it...yet. I just got this system a few weeks ago and have a hard time putting glue on something so new (as if it's broken). When it gets to the point where it'll hamper my driving, I'll glue it.
Great advice!
#612
Ooooh! You beat me to the punch!
Great advice!
Great advice!
#614
Great advice!
Great advice!
A couple drops of Shoe Glue, CA or servo tape solves any problem. If you really do not wish to glue the foam down then I suggest using a wrap of friction tape under the foam, that will be better than nothing.
#615
Ok, I learned a lot painting my radio yesterday. I had the goldish/champagne colored 3PK. It was starting to show some age and the radio that Johnnyboy painted was too sweet to pass up. So I painted mine. I'll post pics tonight.
1. Don't dip the radio plastics in acetone. Although some acetone comes in a plastic bottle, it's a different grade of plastic. I was able to use fingernail polish acetone to remove paint errors with no effects. But when I soaked the module cover it softened the plastic. After the piece dried it was back to normal. But there is some pits and gouges from trying to remove the original gold coloring.
2. I found plastic paint, from Dupont I think, at a department store; Wal-Mart, Target, Lowes, Ace Hardware, etc. No priming required. I don't know if it will last very long, but I will find out soon enough.
3. Make sure the parts are very clean. This paint won't stick to grease or nitro that may have landed on the radio. This is why I needed acetone in the first place, to remove what I had already sprayed. I ended up with some fisheye paint spots. The acetone easily removed the fresh paint with no ill effects to the plastic. I used a paper towel with acetone, instead of soaking the other parts.
Well I'll stop there before I bore you any more. I'll have pics up later. I just painted it white like Johnny Boy and I like it.
