HOBBYWING TECH SUPPORT 1/8 & 1/10 OFF ROAD
#7141
Well, got my ESC's yesterday! Installed em and believe it or not the set button on this new WP SC8 ESC has a faulty "set" button as well. I couldnt believe it! What the odds ?!?! Really? I have owned about 30 HW's and no issues and now two units are faulty back to back! Well, its getting a bit frustrating now. I just wanna run my Stampede!! Its been a month now. I wonder if theres a number of pieces w bad switches?
#7142
Program switch
I have a hobbywing xerun that I jus put on a hpi firestorm it was a nitro car and I installed it and it has a power switch and the program button on it I was wondering if theirs a way to bypass the program button or if u have to buy a new switch
#7144
Paul Rush
#7145
Just wanted to say thanks for the great support by Hobbywing. Angelo always helps me out immediately.
God Bless!
God Bless!
#7147
hey guys I try to get some items from FALCON SEKIDO and every time I put the code in they gave me it doest work has an yone dealt with this yet
#7148
Which motor and esc for 1/8 buggy
Thinking bout getting electric 1/8 buggy. Which esc and motor combo would you guys recommend? Also how do these hold up compared to the other brands? Been out of racing for a while. Was into nitro but every one at the track is running electric now. What about 1/8 truggy what motor would you guys recommend for that class?
#7149
I would go with that for both with your choice of motor. Hobbywings are top notch budget friendly units that can hold up to tekin or any other brand.
#7150
If you mean your membership discount code, i had no problem using mine thursday, basically got my sensor wire free with it. It may be case sensitive.
#7151
Should I run the esc fan on justock with Novak SS Pro motor 17.5?
#7152
what bearings does the xerun 36356 4000 take.
cant seem to find it on there site anywhere.
thanks mike
thanks mike
#7153
I don't run one with my 13.5 stuff. The speed control doesn't get hot. Granted I'm in PA and I'm sure your temps are higher in AZ. I would just check the temps when you get off the track . There is no negative to running a fan. Plus IMO its a good thing to have if in say a buggy with limited air flow.
#7155
I just sent in an xtreme stock speedo with bad motor outputs in for warranty, I was told it could take 10 days to repair. I just got a new one in the mail haha. Thanks hobbywing for the quick turn around.
