DX3R PRO 3CH DSM2 Racing System by Spektrum
#481
if your current channel is fuzzy the TX will try to find a cleaner channel
older DSM1 & 2 only did that at first handshake
supposedly DSMR is a bit "faster" but its already superhuman fast anyways.
(can't tell any difference between 5.5, 11 or 16.5... its all in the mind!!)
and the TXs have the sharkfin aerial, probably a bit tougher than the ole floppy snakebean
i might buy a DSMR when i find a need for 4th channel.
#483
Help with DSMR and DSM2 compatibility
If I buy a new Spectrum DSMR Transmitter, will it bind to and work with all the old Spectrum Receivers (DSM2?) I have in my 8 other on and off road vehicles? Right now I have the DX3R Pro and want to buy a new DSMR radio as a graduation gift, but I want him to be able to still drive my cars with his radio until he gets his own. (I'm left handed and he is not).
#484
#485
Got the answer to all my questions thanks all! Bought the DX4S has all the features I wanted & its in stock so it will be here in time for a graduation present.
#487
hi
i order them in bulk from hong kong you have to buy 40 or more if you like i can sell you a set for 15 shipped i make rx packs out of them and sell them for 30 shipped
as for how i did it ill make a youtube vid on how i did it and how to make a charger to charge the cells in the next day or so
#488
dx3 r pro travel
hey guys got a slight issue with the dx3r pro radio.
just swapped out the radio gear for the hotbodies d812 buggy.
upon setting up travel end points is set to 150 % left and right with 100% steering rate.
tho i dont have full lock steering left and right the steering is set just shy of full steering left and right.
steering servo ko propo bsx servo.
any help appreciated
ps: i think is the original software hasnt been updated (unsure how to update anyway)
#489
DX3R PRO problems.
My radio has a evil mind of its own. It does what it wants...glitches...goes full throttle...doesn't want to do anything. It does this with every vehicle I have. Tried a different radio and bind it to the receivers...everything ok! The radio maybe has an hour on it tops so I hope I can get it straightened out! I love the radio! I guess I have to call Spektrum and see if I can get this fixed or do you guys have any ideas? thanks...Jimmy
#490
#494
Vibrating but not working
Hi, I recently bought a used DX3R Pro which worked great for maybe an hour's total use. It has now stopped working, only vibrating constantly with a dimly lit LCD. I asked my wife, she didn't do this...
As I clearly have no warranty, and on a tight budget, is there a remedy I can try to get it working again? Google tells me that it is a "send it back for repair" situation, but all those posts are over a year old so I'm wondering if a solution has been found that my search terms didn't pick up.
I'm happy to take it apart myself if it's a relatively easy fix. Just trying not to spend any more cash on it right now. Thanks in advance for any advice.
*edit. I should mention I'm in brisbane , Australia if anyone knows the best place to go for repair if necessary.
#495
