DX3R PRO 3CH DSM2 Racing System by Spektrum
#331
@ BullFrog
http://www.amainhobbies.com/product_...el-Orange-DX3S
Not sure on the brake disc but it's likely a dynamite product as well.
#334
You have to adjust your car's brakes so they are engaged when you let up on the throttle. It is easier to do this mechanically by adjusting your linkage.
You can adjust your throttle EPA so the servo applies pressure on the brake when in neutral. Just play with the settings until you feel it works for you.
You don't have a drag brake setting on the radio, in electrics it is a function of the ESC, in nitros it's adjusting the linkage or servo movement.
#337
integy?
Spectrum Adapter
http://www3.towerhobbies.com/cgi-bin...?&I=LXAWXZ&P=0
1 of several wheels.
http://www3.towerhobbies.com/cgi-bin...?&I=LXBBGF&P=0
#340
does the dx2s share the same steering wheel and mounts as the dx3s/r ? after seeing those wheels i want one now, thanks guys lol
#341
servo speed
hi, I'm interested in moving up from the DX3R to the 3R Pro for the servo speed for steering(oval) I've heard this is really just a frame rate adjustment of a few settings vs a true percent 0-100% to adjust in speed like a Futaba or KO...could someone confirm that or not? thanks
#342
All I can say is I had a Airtronics M8 for many years until last month. the Pro has many features I've never had. I also switch all my cars to digital servos from analog. With the setting on the Pro (1 analog and 2 digital) and the new servos it is much better and smoother and quicker than before. As for Oval I'm a road racer that races oval lately once a month.I know how the oval truck drove with the M8 compaired to the new servo and radio.The way I can explain it my oval car is as good as my on-road car. It drives smoother and as easy as my on-road car. I can move over and go anywhere I want on the track under total control. This is a awesome radio. I a few weeks I'll be going to a big race and I can compair the two radio as my teammate has that radio.
#344
I just bought a DESC from a buddy of mine. He had put in a Havok Pro SC but never run it, just set it up. I put my spektrum DSM2 radio gear in a tried it in front of the house and all seemed to be fine. Today when i got to the track and turned everything on it acted like it was glitching and would not work. Eventually the power light on the receiver would not come on so i thought it was a bad receiver. Pulled the receiver out of my losi and tested and it seemed to be ok which lead me to think it was the receiver as well. I put that receiver back in my losi (with a Tekin) and ran a pack with no issues so i decided to put that receiver back in the DESC so i could at least try a pack with the truck. Same thing happened with this receiver so now i have 2 dead receivers and it appears the esc is the culprit. What could cause this? I have checked all my connections and everything is fine. To say i am upset would be the understatement of the century
#345
lifepo4 14500 3.0v??
Hi again,
Man, I searched everywhere for this battery, but only found 600mah and lower...where in the world did you find these babies?
Thanks again,
Keoni
Thanks again,
Keoni
here is a pic of my life cell mod the life cell are the same size of a AA and i used the stock battery tray and they install just like the AA do but there is only 2 used
All i do to charge they is take them out and put them in to my life charger and it only takes 15min to chage
i have about 23hr on the same chage and it still going strong
now if i can only get the cover that spektrum use to cover the 6 cell battery tray to make it a 4 cell so i can cover the other 2 spots that are not used it would look stock lol
