Viper RC -
reponse
Hi to all,
I would like to have some tips for choosing my next mail:
I currently owns a durango 210 (4X2) with VTX10 combos + VST8.5T for 2 years is I am really very happy.
I just purchased a YOKOMO a B-III MAX4 to try a little 4X4, is I want to start on a Viper rc combos for the latter, but better worth a controller or VTX10 VTX10R?
as I wish to make an engine VST6.5T, but I have little for a 4X4 its heated more than 210
What do you think, thank you for your advice at all.
Thank Nico from France
Thanks for the reply,
It came with the 1900kv tekin. It isn't bad but to keep up it would be nice to have the extra power. The other reason was to not have to push it as hard as I do now. The gearing in this is 18/44 and it thermals on the motor. I have the cutoff at 220*. To get it not to temp I changed the throttle EPA in my mt4 to 85% but now it really has issues keeping up with the nitros. I was also kicking around a Orion 2500kv. I know it's a lot of motor but I am pretty set on stepping up. Any thoughts on gearing for either motor?
Also curious if you or anyone else has any ideas on my b44.2.
Tech Legend
Cain - wow, a lot going on there. Might be better to handle through PM. Send me your current brake settings - so I can see to make a recommendation.
Couple other quick notes. If your voltage cut off was at 6.8, that's already high, then the VTX8 actually starts to activate the cut off a few tenths earlier. So with a 4 pole motor and all that current draw - it was probably touching the battery cut off. I have seen data showing a battery can drop 1 full volt with some amp spikes from a 4 pole motor.
Also with temps - cut off was at 240 - but what did you measure? If it was up towards 160 might have hit the cut off from the internal readings on the sensor plus any variance in the sensor - there is always a variance between mfg's. More via PM.
Thanks though for the pm! For brake settings I'll send and confirm but its most likely whatever is stock to the profile as I just used those profiles in the book.
Reason I ask that is are you under geared? in general depending on the vehicles I have in the past used gearing in the 20T pinion sizes on 200 ft straightway tracks, running with nitros. The motors from what I have in seen 1/8 scale can pull the gearing. If however you are undergeared, you can help up the motor quick that way too.
Speaking of profiles, is it recommended to say load a profile you like from the stock ones, then copy them to the other open profile spots if you want to use those and modify?
Hi to all,
Trojanman88- if you feel that you are driving at full throttle a majority if the time around the track, you many be undergeared --- which can cause the motor to get too hot. Last weekend I ran 18/46 with a VF8 2100kv motor (AE car), I could keep up with nitro cars (as long as I wasn't crashing - driver error). But I could see that if you geared too low and on the throttle for longer periods of time, it can heat up. But be carefull - 2700, 2500kv can be a bit extreme for racing.
I have the motor temp cutoff turned off on my VTX8.
Due to space I have to chance my reciever to a smaller one of the same brand. should I re-calibrate the esc for that combo after I change to the mod profile?
Still no thoughts on the b44.2. I ordered the fan for the vtx10 today so I will see if that helps. If I were to try and start with a generic profile which would be best? I plan on running this buggy Wednesday and would like to get the temps right prior. Please help, any info or insight would be great.
Moderator
Sounds like I am probably over geared with a 18/44 and the 1900kv. Both of you I am assuming have 46 spurs as I know that's what comes stock with the 8.2, not sure about the mbx7. I have already ordered a new center diff which comes with the 46 so I will see how that helps.
Last edited by bds81175; 05-20-2014 at 04:59 AM. Reason: Egads...didn't even see it after having it pointed out
He means more esc temp, less motor temp
Tech Legend
don't bother with timing, especially in a 1/8 on 4S.
WHere are you topping out down the longest straight in your buggy?
Do you find you are at close to full throttle around all the track, if so, you could be undergeared.
Capacitor questions...
First, on the new cap that comes on the BE series esc's, it says on the product page that it must be used with A55 (I'm also assuming A55 and up). Does this mean that if you're running A55 (and up) that you have to use this cap or does this mean if you want to use this cap you must be running A55 (and up)?
Second, what is the real difference with the different cap packs (remotely mounted) that y'all offer. I see the standard BE one, the one with the 4 caps in a row and also a pack of 6 caps and one with 9. I understand the basic premise of caps reducing voltage ripple, etc... My son has been led to believe that for his stock racing (different brand of esc), that he'd benefit from adding additional caps to his existing esc. His current esc has one cap (provided by the manufacturer). Would he benefit from the 4 cap setup? Would he benefit more from the 6 or 9 cap setup? Thanks.
