Like Tree4Likes
Viper RC -
Old 03-15-2011 | 10:16 PM
  #811
smokinu's Avatar
Originally Posted by ohiostatechamp
smokinu, have you tried raising the receiver voltage on the viper speed controller to help with the voltage drop due to the digital servo?
i have. i dropped it though from 6v to 5v the savox is just that fast.. its the 1258tg.
Chris, im free all damn day long you know where i live just drop by dude and you can get your sc tires then too.
i am not sure if you were being sarcastic on the solder.. but i do need a new iron.. saving up for one now!
smokinu is offline
  #812
Dlewis4's Avatar
R/C Tech Elite Member
The voltage isnt what matters. Its the amperage.
Dlewis4 is offline
Old 03-15-2011 | 10:22 PM
  #813
jdegraff57z's Avatar
Just makes me want one that much more when they release
jdegraff57z is offline
  #814
smokinu's Avatar
Originally Posted by Trevor Williams
that rear ballcup/turnbuckle isnt looking good.....Oh SnAp!
yeah, the guy that hit me on the back straight did a number to my car.
chunked idler gear and broke my ball diff screw.
and tore half my tabs off on the 13.5
the right tab was worse with out solder on it. and the right side of the middle tab is bent up as well.
smokinu is offline
Old 03-15-2011 | 10:26 PM
  #815
smokinu's Avatar
Originally Posted by mini-dub
Our esc's all use a very high current switching BEC and also feature a high current receiver cable. Standard receiver cables are 30 strand count, ours are 60 strand count. In other words I think you won't get any Spektrum brown outs even with that Savox servo. I run a Spektrum servo in my 2wd, which are built by Savox, and it works flawlessly
i tested it with out the cap was still having brown outs.
ill test raising the voltage up i can always add expo to the servo by my radio
smokinu is offline
Old 03-16-2011 | 12:45 AM
  #816
mini-dub's Avatar
The good news is you can order replacement solder tabs
Also, the load on servos remains pretty similar regardless of operating voltage because the demands to turn the wheels remain consistent. The current draw when running a higher bec voltage (say 6-6.5v) will likely be lower than when running a lower bec voltage (5.0v). Low voltage forces more of the servo watts to come from current draw, high voltage allows more of the servo watts to come from the additional voltage. Remember P=IV
mini-dub is offline
Old 03-16-2011 | 06:56 AM
  #817
macdude's Avatar
Originally Posted by smokinu
you mean the spektrum cap? plugged in behind my rx? it stops brown outs from the savox servos.
Probably it is the receiver and not the servo. I have seen this pretty often lately. Now occasionally it is the servo but most of the time the receiver is just giving out. And Spektrum seem to be the worst.
macdude is offline
Old 03-16-2011 | 07:44 AM
  #818
SuperEk4's Avatar
ordered my combo, wonder will it come with a free pit towel lol
SuperEk4 is offline
Old 03-16-2011 | 12:28 PM
  #819
smokinu's Avatar
i have 4 rx's no matter witch one i use from the oldest to the newest rx that i have witch is a few months old now.. it browns out with out the spektrum cap.
the savox servos are pretty power hungry and the spektrum rx dose not like to drop voltage
having that .2oz in a cap with some wire to know that my rx will never drop out of power is a key to my mind that gives me confidence on the track.
who likes to think that this lap my electronics might fail?
smokinu is offline
Old 03-16-2011 | 02:32 PM
  #820
smokinu's Avatar
Alright so i just changed the sbec voltage in the esc from 5.0v to 7.0v man that 1258 got fast.. i also have no more spektrum brown outs.. i held the car down and cranked the servo back and forth as fast as i can, and still worked flawless.
smokinu is offline
Old 03-16-2011 | 03:18 PM
  #821
Lax Legend's Avatar
Where did you order the combo from?
Lax Legend is offline
Old 03-16-2011 | 03:58 PM
  #822
smokinu's Avatar
from the viper team.. hes a team driver.. at least i am under the impression that he is.
smokinu is offline
Old 03-16-2011 | 04:53 PM
  #823
SuperEk4's Avatar
Yes I m! N I m waiting for Sct motor also.
SuperEk4 is offline
Old 03-16-2011 | 05:04 PM
  #824
Dlewis4's Avatar
Didnt know we were working on a S/C motor?
Dlewis4 is offline
Old 03-16-2011 | 05:06 PM
  #825
SuperEk4's Avatar
Yes weylin told me they hv tested n will release soon
SuperEk4 is offline
